Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-06-2004, 09:33 AM
steve olah steve olah is offline
Send a message via AIM to steve olah
Question super charger or turbo
does anyone have either on of these forced induction systems on there car cause if they do can they tell me how they like them and tell me witch one they like better. i kinda want a super charger myself but i wanted others opinion.
Old 05-06-2004, 02:49 PM
soccmid soccmid is offline
Send a message via AIM to soccmid
big question of site noobs njus simply search u will find a plethora of info
"You can't do anything worth doing in life without taking a chance" - me
funny shit
Old 05-06-2004, 04:31 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: super charger or turbo
Try looking in the Turbo/Supercharger/N20 forum you will probably find more opinon's there.
Old 05-06-2004, 09:16 PM
del del is offline
móddə rąytər
only honda i'd recommend a jackson racing supercharger for is the prelude. no other honda is worth it compared to turbo IMO. it actually helps quite a bit on preludes. still not as flexible as a turbo, you're kinda stuck with whatever it provides. but on preludes, it's not a bad alternative to a turbo. like whtteg said, check out the turbo/supercharger/n2o forum. if for any other honda, i'd recommend the turbo over the supercharger everytime. but being prelude-specific, i would certainly consider a supercharger as an option.
Old 05-07-2004, 09:10 AM
do yall know the actual forum i can go to
Old 05-07-2004, 10:57 AM
del del is offline
móddə rąytər
http://www.automotiveforums.com/vbul...lay.php?f=1038
Old 05-07-2004, 12:43 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Sadly, supercharger applications are only available for the 5th gen Preludes. 4th genners are left out of the rain.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 05-07-2004, 04:05 PM
del del is offline
móddə rąytər
Re: Re: super charger or turbo
there have been a few people who have successfully retrofitted the JRSC into a 4th gen. involves more work and more hassle and not really worth it all IMO. but it's unique.
Old 05-09-2004, 05:39 PM
Dr_Krisp's Avatar
Dr_Krisp Dr_Krisp is offline
Send a message via AIM to Dr_Krisp
i personally think superchargers should not be used on a four cylinder engine, that's what turbo's are for
Just because i have a small penis does NOT make me any less of a man.
Old 05-09-2004, 07:34 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Re: Re: super charger or turbo
doesn't it involve some kind of modification to the firewall?
Old 05-09-2004, 09:00 PM
ttsupra15 ttsupra15 is offline
Hey I would definitely think about it hard cause its expensive. But if u want power more on demand i would go supercharger cause its always ready to go. Turbo has to spool up for a sec or two, but they sound cooler cause of the wastegate. Also turbos are extremely hot I would go supercharger my friend has a 98 lude and he is loving it. It got him around 50-60 rear wheel hp. good luck and if u have any sound clips of an apex n1 sytem send me them thanks
Old 05-09-2004, 09:24 PM
del del is offline
móddə rąytər
rear wheel hp? i'd love to see that.
Old 05-09-2004, 10:40 PM
AcesHigh's Avatar
Prelude Guy
The hissing sound from a turbocharger system comes from the bypass valve. Turbochargers are also more efficient than superchargers, and more flexible. And superchargers are good on any car regardless of cylinder count.
Old 05-10-2004, 01:01 AM
error54 error54 is offline
Send a message via AIM to error54
Superchargers are less efficient due to the fact that they take power from the pulleys which will decrease the bhp to whp ratio. True, turbos do have a spool up time but they are capable of running much higher boost than a supercharger.
Import vs Domestic
-Brain vs Brawn-
To Each his own....
Old 05-10-2004, 01:07 PM
AcesHigh's Avatar
Prelude Guy
That's 100% correct. The term coined for the supercharger's ineffiency is leaching. It takes power to make the power. Turbochargers are using the flow of wastes so 1) the turbocharger is not hindered in terms of how much boost they can produce, it is dependent on how much exhaust your engine is expelling 2) boost is flexible and can be controlled easily using a wastegate boost controller, and 3) turbos are also typically quieter. If you want a short spool, go with a tiny turbo. If you want an incredible amount of power, go with a big turbo. If you want no spool and a moderate amount of untunable (for the most part) power, take the SC. It's all a tradeoff of one thing for another.
