Old 05-05-2004, 11:38 PM
Shadivak Shadivak is offline
Serpentine Belt Replacement
I have a 96 Grand Am GT and was wondering if it is possible to replace the serpentine belt without removing that damn motor mount. I'm guessing no. Anyone know?
Old 05-06-2004, 12:05 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: Serpentine Belt Replacement
I have not seen under the hood of a 1996 Grand Am GT but in my opinion, the serpentine belt are designed to be removed once you loosen the serpentine belt tensioner and without having to remove any other component.
Some tensioner can be loosened just using a ratchet or using a close-end wrench and then turning it to loosent the tensioner so you can remove the serpentine belt around all the pulleys.
Old 05-06-2004, 12:09 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
I agree with mr slade , my 85 was like that too , i thought the engine mount was in the way , turned out the belt tensioner loosened enough to slide it on past the mount i thought was in the way. Just got to look at how it could go on differently , like from a below perspective. I hope thats understandable.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 12-08-2004, 01:43 PM
blackhalo blackhalo is offline
Banned
You guessed right! You have to put a juck under the engine, remove the motor mount, replace the belt, re-attach the mount, and remove the jack! WahhhLLLaaaaaahhh!
I know! I know! this what you are thinking ----->
Old 12-08-2004, 02:27 PM
Chazman Chazman is offline
I have a 94 3.1L and yes the motor mount is in the way on mine as well.
Old 12-08-2004, 09:55 PM
justin0717 justin0717 is offline
if you have the 4cyl then no you do not need to.
1996 GA SE 2.4L- sold
1999 GA SE 3.4L - newest
Old 05-30-2006, 08:00 PM
donnap1957 donnap1957 is offline
Are you saying you just loosen the tensioners then remove and replace the serpentine. I have a 96 GA 2.4L
