Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 05-05-2004, 09:33 PM
aznracer520 aznracer520 is offline
burnout
how do you do a burnout on a 240sx manual??
step by step plz.
Old 05-05-2004, 09:47 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: burnout
spin the back tires
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 05-05-2004, 09:48 PM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
an actual BURNOUT or spin the tires?
BURNOUT
1) get in car.....
2) start engine LOL
3) Hold in clutch
4) Step on brake with either heel or toe
5) Step on Gas with either heel or toe, all the way at first is fine if you can do up to step number 6 quickly
6) Sidestep(move foot off clutch pedal in a fashion that lets the clutch engage in the fastest manner)
7) Floor gas to keep tires spinning
8) Modulate Brake pedal so you use just enough to keep it from moving
-----Burnout-------
Hmmm clutch pedal in, throttle pedal down, sidestep clutch
Be warned, sidestepping a clutch from a stop does not let it last very long LOL...on dirt its not as bad but on the street it wears it a lot.
Old 05-06-2004, 11:33 AM
KenOhki2112's Avatar
KenOhki2112 KenOhki2112 is offline
Send a message via AIM to KenOhki2112
Start easy.. took me months to get a sustained burn out, since the car has lower HP you have very little room for error. Do it in an abandond parking lot so you don't hit any one.
stop, put the clutch in, 1st gear
rev up to about ~3000
release clutch, steer to avoid things.
If you didn't peel out, you either your clutch is getting very worn, or you wussed out and didn't release it. If you are having trouble fighting the impluse to feather the clutch (it's hard to get used to) then place the side of your foot on the clutch so that it's barely on, then when you rev move your foot to the side so the clutch goes flying up full speed.
once you break traction, to get the most out of it you will rev the engine up to 5000-6000, keep it off the redline, if you do red line abort the manuver by letting go of the gas and letting the engine slow down.
-KenOhki2112
Old 05-06-2004, 03:13 PM
Suislide's Avatar
Suislide Suislide is offline
common sense, i would think...
it's not unique to a 240SX either. this really has nothing to do with the car itself.
i would move this to another forum, but i don't think there's one it belongs in.
so since you got your answer, we'll just close it.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
