Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 05-05-2004, 06:26 PM
c2Elliott c2Elliott is offline
Question Where Can I get these headlights
Hey does anyone know where I can get the JDM low rise headlights?
Go to this site if you want to see a picture.
www.cardomain.com/memberpage/534752
I don't know how to put up pictures, sorry.
Old 05-06-2004, 12:32 AM
jazon720 jazon720 is offline
Re: Where Can I get these headlights
not sure, but you could i.m. the guy on car domain and ask him where he got it.
Old 05-06-2004, 08:06 AM
Turbo Tony Turbo Tony is offline
Hiya, If you are only interested in the rise of the headlight, there is a very easy way to do this. Open up your hood and pop-open your headlights in full (headlights on). Now inside the spare wheel compartment just behind the headlight you'll see a red knob with a circular arrow, turn this knob and the headlight will begin to lower, lower it as far as you want to get that killer mean look. Now be carefull when you turn off the headlights from inside the car DO NOT turn the switch completely towards you to ( is it close?) otherwise the headlights will close completely and will pop-up completely when you turn them on again, you have to turn the headlight switch to the second to last notch wich I believe is OFF (my car is still in storage can't remember off hand what it is). There a couple of draw back to this
1) Unless you have custom made headlamps made for a narrow opening
like to ones found at http://www.roguesystems.co.uk/products/
you will get very little light driving at night (at a routine traffic stop my friend was asked if there was a problem with his headlights)
2) If you flash your highbeams the headlights will pop full up again and close completely..
Hope it helps..
cheers
Tony
Old 05-09-2004, 12:36 AM
scarecrowX scarecrowX is offline
Send a message via AIM to scarecrowX Send a message via Yahoo to scarecrowX
i believe you can modify the actuator arm to change how high the headlights go. however, unless you have smaller lights in their place that are properly aimed, this renders them completely useless at night. a guy by the name of "kustomplay" on mr2oc took this approach and it seems to have worked well.
Old 05-11-2004, 06:43 PM
Thanks you guys,
But I'm looking for a site that actually sells the conversion
But these are all good Ideas
Old 05-12-2004, 12:14 AM
he sells them too dude. www.kustomplay.com $63 shipped, or so the GB info says..
http://www.mr2oc.com/showthread.php?s=&threadid=135
Old 05-13-2004, 07:33 PM
Thanxs ScarecrowX
But I couldn't find them on his site.
