Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 05-05-2004, 05:06 PM
brightfame brightfame is offline
Question Door Wiring
I have a friend who has a 95 Bonneville and boughte a used to replace his damaged door. When we picked the door up the wires had been cut. Before I put this door on I need to know if there is a wiring harness or do I have to match up all the wires from the car to the new door? If there is no harness is there a wiring schematic so that I can make sure that all the wires match up? Thanks
Old 05-05-2004, 06:10 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Re: Door Wiring
Why don't you just keep the old wiring harness. Al you have to do is remove the door panel, unplug everhting and chase the wiring out of the door then you can fed the harness into the new door. Why go thru all the trouble of splicing 30 wires?
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 05-06-2004, 08:17 AM
Cool Thanks
Thanks that is exactly what I am going to do!
