Old 05-05-2004, 04:16 PM
slo89 slo89 is offline
Send a message via AIM to slo89
B16 help
i just swapped a b16 in my 89 std hatch. everything is in and done. the car will start but it wont tach past 3grand. The wiring is straight and so is the crank angle senor. i have tried about 4 diff distributors and ecus and its still doing it. i was wondering if anyone has any idea whats going on, etc. let me know
Old 05-05-2004, 04:50 PM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
Re: B16 help
Well without knowing what codes the ECU is throwing I would guess its the flux capacitor.
DOHC ZC 89 DX HATCH
Old 05-05-2004, 06:30 PM
Re: B16 help
its throwing a code 4 (CKP - crank position sensor ), anyone have any idea whats wrong.
Old 05-05-2004, 06:51 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: B16 help
Well, it's definitly something with the distributor. The crank angle sensor is in the distributor. So either you've got 4 bad ones, or your wiring is messed, might want to double check your timing too. Not much else. Are you using the B16 distributor??
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 05-05-2004, 07:10 PM
Re: B16 help
its not in the distributor. all the distributors work fine. i have a b20/vtec in a crx and they all work fine on that, i double checked them after trying them on the hatch and they are working fine. yes they are all b16 distributors. the wiring is also straight. any other ideas
Old 05-05-2004, 08:31 PM
4G4D Store's Avatar
Re: B16 help
the only 4 things that come to mind are distro, timing, wiring or ecu - can't think of anything else.
Old 05-06-2004, 03:48 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: B16 help
when it sticks at 3 grand is it miss firing?? bakc firing, or just doesnt go further and dies?
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 05-06-2004, 04:35 PM
Re: B16 help
it is missing somewhat and all like the crank angle sensor is bad but it isnt and the wiring has been checked and checked again.
Old 05-06-2004, 04:36 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
I'll go get the FSM
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 05-07-2004, 08:34 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: B16 help
check your timing man, i bet your like 90° off.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-07-2004, 11:50 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: B16 help
dude either ur wiring is screwed or ur timing is off. I would say that it's ur timing. Put ur car in fifth gear, then pull in forward till the lower timing belt TDC mark (the one that is separated from the other 3 marks) lines up with the pointer on the lower timing belt cover. Now, see if you cam gear is lined up with the mark on ur upper timing belt cover. If all those line up, then it's ur wiring for sure.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-07-2004, 09:24 PM
Re: B16 help
it wasnt the timing, i know how to do that after as many hondas as i have worked on. it was just something stupid. 2 wires not even for the crank angle sensor were too close together, not touching or anything but just happened to move them apart and the car runs fine now.
Old 05-10-2004, 10:53 AM
bambam89lx's Avatar
AF - Advisor
Re: B16 help
well, that's why ur supposed to run shielded wire.
Old 05-10-2004, 12:08 PM
SiZ's Avatar
SiZ SiZ is offline
Re: B16 help
Yep, I had the same problem with wires that weren't sheilded properly.
