Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-05-2004, 03:09 PM
Noremac Noremac is offline
Send a message via ICQ to Noremac
Side Mount Intercooler
What are the positives and negatives to using a side mount instead of a front mount?
95 ls with GSR head
aem cai, dc sport header, greddy exhaust, pyr computer chip(red-8500) type r pistons, skunk 2 intake manifold and coilovers, aem fuel regulator, msd ignition wires, unorthodox underdrive pulley And Now Skunk2 stage 2 cams but not installed..
all sleepin in a black body...
Old 05-05-2004, 04:13 PM
boosted331 boosted331 is offline
Re: Side Mount Intercooler
The only times you really see front mounts are on stock applications where they can't block any of the radiator, and it needs to be tucked away in the corner to pass crash tests. Not worth anything in a performance application.
Old 05-05-2004, 07:26 PM
IntegraB16 IntegraB16 is offline
I would definately stick with a front mount intercooler. It will work much more efficiently in the front.
Old 05-06-2004, 12:16 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
the point of an IC is to bring in cooler more dense air, unless factory routed the air you would be bringing in would me warmer less dense are from teh engine compartment..therefor working not nearly as effective as a front mount..the pos. is that it would in no way block/starve your radiator of the same cooler more dense air, especialy when driving. this can be comensated by using a smaller front mount IC that only blocks a portion of the radiator...
I have been working on a schematic on this for a few weeks while bored here at work, i am using a massive front mount XS IC on my sol and i am running vented plumbing and so forth, and increasing my coolant flow in many ways, but im not gonna get into that .. what kind of vehicle si this ?
