99 Tahoe Cam code P0304
This is the discription from the machanic shop
'Cam code P0304 resetting on engine start-up will not clear. Will need furhter testing to determine cause of failure conditioning turning MIL on. Note: Vehicle has some hesitation ' History: I replaced the intake manifold gasket because of coolant leak, took the vehicle to a shop and had the timimg and cam sync set. There is still hesitation when I acelerate and the check engine light stays on. Do anyone have any Ideas? Help anyone, I'm desoerate here.
Re: 99 Tahoe Cam code P0304
Are you sure that is the code?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Yes that's the code that the shop said they needed to investigate more. P0304.
Is there anything I can do to try to rectify the problem or am I screwed and stuck with taking it to a shop? It seems by the time I'm done fixing this truck, I could have used that money to buy a brand new truck right off the shelf. |
Re: Re: 99 Tahoe Cam code P0304
A P0304 is a misfire code specific to # 4 cylinder..
I would look for a fouled plug, bad plug wire or the possibility that an injector is clogged or not firing.
