Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-05-2004, 11:57 AM
tressler tressler is offline
1993 Chevy Caprice Classic SW, Strange heater problem
I have a strange heater problem on my 1993 Chevy Caprice Classic SW. If I select "heat" on the heater control. I have hot air blowing out at my feet, just like is should. Everything works just fine, until there is a load on the engine. For example, ff I'm going up a hill, the hot air then comes out of the vents in the dash. As soon as the load off the engine, the hot air then comes out of the heater vents again. At first, I thought it was the heater control malfunctioning, as I have had problems with those in the past, but it is definately associated with load on the engine. Most likely a vacuum leak somewhere. Any thoughts? Ideas where to begin to find the leak? Thanks
Old 05-05-2004, 08:44 PM
CD Smalley CD Smalley is offline
Re: 1993 Chevy Caprice Classic SW, Strange heater problem
You have it right. It's a vacuum leak somewhere. You will have to run the lines under hood and behind the dash. I'd look for a failed vacuum resevoir under the dash somewhere....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 05-06-2004, 01:57 AM
burnM's Avatar
burnM burnM is offline
Run the engine + heater. Listen for a vac leak with a piece of vac hose to your ear, and the other end wherever you suspect a leak.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 05-06-2004, 08:14 AM
That's a good idea, a homemade earscope. I need to find the time to do this soon. Summer is almost here, but I don't want to let it go until December! Thanks, I'll post what I find.
