Old 01-15-2002, 08:33 AM
FLAWLESS FLAWLESS is offline
Send a message via AIM to FLAWLESS
TECH: Switch for Reverse Indiglo Gauges?
I have installed my new Reverse Indiglos on a 12v switch so I can leave them on even when the car is off for show etc.
I had my old standard indiglo's wired to the parking lights so they automatically came on.
Is there a way that I can have them ALWAYS come on with the parking lights, but still be able to flip my switch and juice them up when the car's off?
I was thinking of running a wire to the 12v for the gauges -from the parking lights (+) after the switch. But MY CONCERN is that power will back feed into the parking lights circuit when the car is off and the gauges are on. Should I be using a RESISTOR or RELAY in some capacity?
Old 01-15-2002, 04:54 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
You just need a simple switch called a 'Single Pole Double Throw' (SPDT)
This kind of switch has three terminals. Attach the one in the center to your indiglo power wire; one side to the +12V; and the other side to the parking lights.
When the switch is in one position, the indiglos will be attached to the +12V; with the switch in the other position, the indiglos will be attached to the parking lights.
Make sure that there is a fuse somewhere between the +12V and the indiglos though! There should be some kind of always-on accessory fuse already in your under-dash fuse box. Take the +12V wire from there.
Simple.
Here's a picture of a SPDT switch - notice the three terminals - this one would work but would be WAY overkill You could find a nice sized toggle or rocker switch at your local radio-shack.
Old 01-15-2002, 10:41 PM
Someguy Someguy is offline
Send a message via AIM to Someguy
I think we have that exact same switch on the backside of one of our radar system's racks.
Old 01-16-2002, 08:25 AM
YEAH FRITZ U are the best. I knew there was a simple solution! Thanks, I'm gonna wire it tonight and I'll let you know how it works.
-Anth
Old 01-16-2002, 09:24 AM
Hey Fritz one more Q then I'll leave you alone.
What rating fuse should I use for this application...and where should I fuse it...from the switch to the gauges right? Thanks man.
Old 01-16-2002, 10:12 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
sorry im not fritz, but id go 20A fuse to be safe.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-16-2002, 02:01 PM
fritz_269's Avatar
I doubt the gauges take 20A to light... a 5 amp 'slo-blo' fuse would probably be ideal, but anywhere from 2-20 amps is probably fine. The instructions with the indiglos might suggest their mfg. recommended fuse rating as well. You just want to make sure that if your wiring or the indiglo gauges short out, that you don't heat up a wire & start a fire.
the wiring would probably go like this (pardon the crappy ascii art):
Code:
+---accessory----5Afuse------*
                     switch->  *-------------indiglopower+
+---parkinglights------------*
The parking lights already have their own fuse, so don't worry too much about that wire. If you look at the fuse box under your dash, you might find that there is an unused fused accessory terminal, just waiting for you to use it. That way you wouldn't have to add another fuse and holder. Note that there are two kinds of accessory terminals - one which is always-on, and one which is switched by the ignition key; you obviously want the always-on variety.
Good luck.
PS> Make sure the switch you buy is rated for 5A @ 12VDC or higher.
Old 01-16-2002, 02:25 PM
I was gonna wire it like this. (The switch I got has 3 terminals, ON/OFF/ON.)
12V+ constant from fuse panel to ON
12v+ TO indiglos to OFF (with fuse on this wire)
12v+ from parking lights to ON
Am I on the right track?
Old 01-21-2002, 10:55 AM
I got the switch from Radio Shack and wired it up. Works like a charm. Looks ugly (it's one of those long black toggles) but it works! Thanks to everyone who gave me input.
where do I find the power supply for my reverse indiglo gauge. 1995 AT honda accord SouljahWon Car Audio 1 08-14-2003 02:38 PM
Reverse Indiglo Gauges for a B16B Ricochet Car Audio 3 07-10-2003 10:22 AM
DIY directions for reverse indiglo gauges? EliteImports '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 02-19-2002 09:42 PM
TECH: Switch for Reverse Indiglo Gauges FLAWLESS Car Audio 4 01-23-2002 03:17 PM
Reverse Indiglo Gauges... foxyracer '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 16 12-30-2001 02:46 PM
