Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-04-2004, 11:55 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Motor Knocking
Ok, I have a 96 Ford Contour GL, It's got that 2.0 Zetec motor with a 129,000 mile's on it. I've noticed when im pulling hill's the motor knocks some what. I've been told it's a loose vaccum hose but I'm not sure, Any help?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-05-2004, 10:46 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
if the motor is knocking its generally a sign of a spun main or rod bearing.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-05-2004, 03:44 PM
pre98zetec's Avatar
Re: Motor Knocking
Ok, I was being told it wasnt that because it doesnt knock all the time. Also relized when i keep octane booster in it , it doesnt knock at all. So im kinda stumped.
-Josh-
Old 05-05-2004, 07:16 PM
are you sure your not mistaking a ping for a knock?
"The CEG Nazi"
www.contour.org
Old 05-05-2004, 09:09 PM
pre98zetec's Avatar
Re: Motor Knocking
Yeah I must be, It's like a pinging, no actually knocking. the car doesnt loose any power or nothing. and it only does it during pulling hill's
-Josh-
Old 11-23-2004, 07:44 PM
myconsvt myconsvt is offline
Re: Re: Motor Knocking
it may be a lifter is getting cloged and that is why it knocks up hills, due to the lifter not getting alot of oil.
Old 04-28-2005, 08:25 PM
riverat440 riverat440 is offline
Re: Motor Knocking
I'm wondering if you have had any luck with your 2.0. I've recently been asked to work on a 96 with the Zetec engine and am having sort of the same dilema. The computer is putting up a 171 code for fuel system lean condition and after driving it have noticed the same symptoms as you. I was thinking if this is running lean it should also be running hot which would create a pinging sound as if the timing was to far advanced. As you are probably aware the timing isn't adjustable so the octane boost is the next best remedy. I was hoping maybe you were experiencing the trouble light also and maybe by now had found a fix. I have searched all over the engine for vacuum leaks but no luck. This one also experiences a bad hesitation when cold and gradually gets somewhat better as it warms up which kinda verifies the lean condition. Don't you just love the new vehicles with no adjustments. Thanks for any input you might have.
