Old 05-04-2004, 09:23 PM
Draxus Draxus is offline
Smile She's smoking :(
My 1985 Chevy Camaro (5.0L 305 V8 ) is smoking. It seems to be coming from the hood under the hood, i can see where, but not what it's coming from exactly. Also if i remove the dipstick it seems to smoke out of that tube. Yesterday I added Restore, that oil addidtive that's supposed to restore some hp among other things. Then I drove it maybe 1/2 a mile, no smoke. Today I drove it a mile, parked it for 4 hours, drove it another mile, then parked it for awhile, then drove it about 1/4 mile a couple hours later. On the way back from the 1/4 mile trip, it started smoking a decent amount.
Any ideas?
Thanks
Old 05-04-2004, 09:27 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: She's smoking :(
sounds like a small oil leak
Old 05-04-2004, 09:29 PM
could also be a water leaK, but when it leaks do you smell oil or coolant?? like antifreeze
Old 05-04-2004, 09:40 PM
I'm actually nto sure i know what oil burning smells like, but i know it doesn't smell like collant in any way. I suppose it's probably oil.
Would one of the oil additives designed to stop leaks work?
Old 05-04-2004, 09:46 PM
i wouldnt suggest an oil additive, i say you should track down where its coming from and replace the gaskit
Old 05-04-2004, 09:48 PM
ok.... i've read that replacing gaskets is quite easy for do-it-yourself type people... true?
Old 05-04-2004, 09:49 PM
my bronco had a cracked valve cover (i will never deal with aluminum valve covers again) i tried fixing it with jb weld, worked for a little while, it started leaking again and caught on fire, good thing i had a fire extinquisher with me, took it off and jb welded the hole side just about cause im too lazy to get new ones,and its still holding up....
Old 05-04-2004, 09:50 PM
well it depends which gasket, a valve cover gasket yes, a head gasket no
Old 05-04-2004, 09:51 PM
nice lookin car by the way
Old 05-04-2004, 09:54 PM
thanks
well i'll take a look at it and see what i can do, thanks for the help
Old 05-04-2004, 09:55 PM
your welcome, good luck
Old 05-05-2004, 12:15 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
exhaust manifold leak by any chance?
