Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-04-2004, 07:09 PM
alphalanos alphalanos is offline
turbo daewoo
i was remotely thinking about if my car were turbocharged, what i could expect to gain. I have an 02 Lanos with a 1.6L ~115 hp 4cyl DOHC FI. conservatively, and assuming the engine was reinforced adequately, what do you estimate a rough gain could be? i dont know much about this so i cant really come up with a HP number. i am assuming i would want at least reprogrammed ECU, new pistons, rods, cams, valves, rework the exhaust, intake and exhaust manifolds, headers. whew. oh by the way this engine has a kind of "knock- off" VTEC system, not nearly as powerful. its called E-TEC and is designed for emissions although it does boost power considerably when engaged, just as VTEC does.
or should i just swap in a B16(18?) Vtec
Old 05-04-2004, 09:55 PM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Re: turbo daewoo
Fuck it, do an engine swap and have one hell of a sleeper.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 05-04-2004, 10:01 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: turbo daewoo
geez this is new idea to me well fact is Daewoo is dead in US so anything you get done will have to be custom there is and will not be an aftermarket for this car brand. It'll be alot of money but you'll be able to do it if you got the $$$
But i'm really going to sugust you save up get a real proformance car or atleast one with a aftermarket or a cult following this sounds like too much work and too little pay off to me
Old 05-04-2004, 10:39 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: turbo daewoo
You'd break maybe 200hp by the time your done.. Not worth it IMO. Swap in a Zetec, Or Vtec
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-05-2004, 03:55 PM
matt11583 matt11583 is offline
Re: turbo daewoo
after you buy all the parts for it and turbo charge it you would be luck to see 250 hp. im guessing more like 220. with all teh money it would take, i sugguest goin out and buying a better car if you want ot start doin mods to your engine.
Old 05-05-2004, 04:50 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
What do you guys mean he will only make 200-250 HP so he should do a swap? Are you guys joking me, a Zetec motor only makes 130 HP, 15 more than his stock motor. Vtec is a very broad term, because there are many different Vtec motors, but most don't even make all that much HP. If you even made 180 HP you would be miles ahead of either of these motors, and you could easily make 180 HP if you turbocharged your motor. Also, swapping these motors will be VERY difficult and VERY expensive unless they are direct bolt-in's...all for an extra 15 HP. Seems like an easy choice to me.
Also, most of the parts you listed as needing for turbocharging your car, you wouldn't. HP for HP, turbocharging your motor will be cheaper. If you swap, then you've spent thousands of dollars for 15 extra HP and you will need to spend thousands more to modify that motor.
Beer tastes better upside down.
Old 05-05-2004, 04:58 PM
pre98zetec's Avatar
Re: turbo daewoo
More like what are you talking about? I said he would be lucky to see 200 if he turbocharged the motor he HAS in the car now. And if he swaped in a Civic SI motor B16A2 (160hp) or a Zetec VTI (142hp) he could make those motor reach alot more with alot less money..
-Josh-
Old 05-06-2004, 03:19 AM
I can't see a motor swap happening for under $1000. After you swapped that motor you would need to spend even more money on mods. Like I said before, do you know it's possible? If the motor doesn't bolt in like it was made for the car, it will be ridiculously hard and expensive. You can't just bolt any motor into any car. Then how much more would you have to spend to make the swapped motor make 200 HP? For three basic upgrades; Zetec cams $399.99, header $374.95, CAI $238. Bringing us to a total $1012.94 for three basic upgrades that might give you 40 more HP. Theres another thousand dollars and you still won't have 200 HP.
For $1500 I guarantee that motor could make 200 HP, and far more if he had the money and knew how to do it properly. With stock internals I can guarantee that it will make 200 HP reliably as long as it's tuned properly.
I don't know why you think swapping in a different motor would be cheaper, turbocharging is almost always the most cost effective HP upgrade. If he's going to swap motors he might as well buy a new car, it's easier, and I can't see why you would do this unless the stock motor is particularly weak.
Old 05-06-2004, 04:48 AM
xyfalconsrock's Avatar
xyfalconsrock xyfalconsrock is offline
Send a message via MSN to xyfalconsrock
Re: turbo daewoo
Go the sleeper idea.How bout a 289 or 302(if u can fit it)u'd have the fastest daewoo in city, and one hell of a good sound.
Old 05-06-2004, 05:02 AM
SCJ428 SCJ428 is offline
Re: turbo daewoo
Ewwww... Daewoo..
take out the wheel arches and impose a V8 on that engine bay!
Old 05-08-2004, 03:44 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Re: turbo daewoo
Originally Posted by SCJ428
Ewwww... Daewoo..
DEFINITELY not the cheapest upgrade but that would make his the fastest daewoo ever.
Personally, i think you should swap the engine to a b18c, its one of the integra engines. i found a good price on ebay it would ad quite alot of power to your ride and you still have the option of adding a turbo and getting even more.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 05-08-2004, 04:02 PM
why didnt i get that VR6.....ahhh .lol
96 EJ6. Future home of boosted B18C1.
