Go Back   Automotive Forums Car Chat > Hyundai > Santa Fe > MY 01-06
Old 05-04-2004, 12:47 PM
nsfdff nsfdff is offline
Send a message via AIM to nsfdff Send a message via MSN to nsfdff Send a message via Yahoo to nsfdff
Question 2003 Santa fe program Keyless remote
Can this be done by consumer or do I need a special tool? I'm sick of waiting for my dealer to get a replacement FOB, they lost the original and sold me the new car without, promising to send a new one when it came. 6 months, no FOB. Got a new one on eBay just need it programmed. I'll buy a beer for the first good answer
Have a great day!
jon
Old 05-11-2004, 09:31 AM
twospirits twospirits is offline
Ex-Janitor of AF
It can be done by both.
The quick self to do method is shown below, for the full method using a High Scan Unit (only at the dealership) see this link.
Transmitter Code Registration (using code saving switch)
Note the ETACS unit is in located in the drivers side under the steering wheel. Behind the Passenger Compartment Fuse box.
The Following User Says Thank You to twospirits For This Useful Post:
w2kbr (08-17-2017)
Old 05-11-2004, 10:28 AM
Re: 2003 Santa fe program Keyless remote
That took me twenty seconds to do. I'd say I love you but then someone would think it was weird and sully the entire feeling of the moment, so HI FIVES! instead! Thanks so much.... had called my dealer and he wanted 35$ to do this assuming I drove all the way there and back. (twenty second fix cost him a customer)
Thanks again!
p.s. where do I send the beer?
Old 05-11-2004, 01:37 PM
Ex-Janitor of AF
Thats okay I'm all beered out from the weekend. Luckly I saw the post, I had lost my link to the forum and could not get back until I got an email that a posting was made, so I followed it and it lead me back to the forum.
I've been busy doing all kinds of modifications and just completed adding a alarm chirp to the pre-2004 models. You can visit my website and look at the mod page. You might find something that you want to do to the Santa Fe and did not know how to do it.
Later Dave
oh forgot webiste is www.santafemods.com
Old 05-13-2004, 07:40 PM
Unhappy
Well, I got the one remote to work... now can't get the second to work. Using the switch, I am able to program one or the other but not both. ideas?
I leave switch off, push buttons on both. Only the last one pushed works.
I leave off, push both at same time. neither works.
I leave off, push one and set. Remove it from area and do second same way. Now the first won't work after.
Can set one or the other every time, but would like both working....
Old 05-13-2004, 07:53 PM
Ex-Janitor of AF
Hmmm it should work. Okay lets see. make sure you do not disconnect the battery.
1-Remove Ignition key from ignition switch.
2-Set the switch on the ETACS from "Off" to "Set"
3-Press the transmitters' door lock button for one second (this sends the codes to the ETACS and stores it.)
4-Do the same with the other transmitter (Press door lock buttonfor one second)
5-Set the ETACS switch from "Set" to "Off"
See if both remotes work. It should mine does and I did it this way.
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
Old 05-13-2004, 08:53 PM
Well, between the two of us I got it going. On my particular remotes, the light will blink twice if i hold the button down long enuf. about 2-3 seconds and then they worked as a matched pair.
Thanks for all the help.
I am a new Santa Fe owner and so far very much enjoy the vehicle.
Old 05-13-2004, 08:58 PM
Ex-Janitor of AF
Glad that you got it working. Trust me, after a few years you will still feel the same way. I do.
Old 07-12-2004, 10:23 PM
dlawrence dlawrence is offline
Program keyless remote
Is it possible to program 3 remotes? If so how? Do you need the dealer to do it?
Old 07-14-2004, 01:48 PM
Ex-Janitor of AF
That I know of, only two FOBs (remotes) can be programmed regardless if its the dealership/service dept or by yourself.
TS out
Old 11-26-2004, 04:31 PM
WD Squared WD Squared is offline
Thanks a bunch!
Just bought a 1 yr old Santa Fe, needed a second remote, took a chance on an ebay purchase, found this thread on reprogramming the keyless entry, and bingo! I'm in business! Thanks a bunch! - Bill
Old 12-01-2004, 07:45 AM
itbedave itbedave is offline
I had a similar problem - bought my 2001 used (1 owner) a year ago but the dealer only had 1 remote. He promised me he could get me a second one for my wife because they also had a Hyundai dealership in town. Months go by and nothing. I call and they can't remember making that promise. Of course, I didn't have him right it down on the sales invoice (lesson learned.) So I found this forum, found a used one on eBay for $5 - followed the programming instructions as seen above, and voíla - problem solved!
I too initially had trouble getting both remotes to take and work. But discovered that I needed to hold down the button a little longer and pause a little longer between pushing the buttons.
And I could be mistaken, but I thought I read somewhere that you could program up to 4 different remote codes with the receiver?
Old 12-03-2004, 08:47 PM
Ex-Janitor of AF
I wished. Throughout numerous online forums as well as talking to the guys directly at Hyundai, it seems that you can only program two FOBs to the ETACS. I wish it were possible though.
Also on some older models like pre-2003 June i belive Santa Fes only came with the two button remote/FOB. Soon after they came with the three button remote. One can get the three button remote and do the above steps and it will work, but the third button would not work for some reason. At least on the ones I tried.
TS out
Old 02-27-2005, 03:39 PM
hyundaiken hyundaiken is offline
This looks pretty simple but do you know if the 2004 Santa Fe can be programmed by the owner? I've looked under the panel by the fuse box and can't find a module that looks like this.
Old 02-27-2005, 10:52 PM
Ex-Janitor of AF
If I am not mistaken the 2002-2005 have not changed that much in reference to the units location. Now I could be wrong cause I do not have a 2004-5, I have a 2002. Maybe one of the resident Hyundai techs can confirm this.
TS out
