Old 05-04-2004, 10:48 AM
Tach_it Tach_it is offline
Send a message via AIM to Tach_it
302 in a 2001 F-150
Is it possible to put a 302, 2001 F-150, possible by will it bolt up to the bell housing of a 5 spd, with out a shit load of money. carb or fuel injected, thanks
Old 05-09-2004, 06:43 PM
wrechman1 wrechman1 is offline
Re: 302 in a 2001 F-150
I don't think it would. as far as a shit load of money, I think you would have to get a new computer, new rearend, new everything, just for that motor to work.
Old 05-10-2004, 01:19 AM
Re: Re: 302 in a 2001 F-150
what if you did away with the fuel ing. and able to bolt to the tranny, minor modifications wouldnt be a prob, thanks
Old 05-10-2004, 12:18 PM
ModMech's Avatar
ModMech ModMech is offline
As far as I know, the modular engines use the BBF bolt pattern, and the motor mounts are completely wrong for a SBF.
Why on god's green earth would you want a pushrod engine in a 2001 vehicle?
Old 05-15-2004, 09:19 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
What year is the 302 and what engine does the 2001 have in it now? There might be an adapter which you can purchase. You won't need to change the rear end or anything like that either. whether it is Fuel injection of carborated, it does not matter...its an easy conversion to make. The only major thing you will have to do is reprogram the computers, but that's not too difficult for someone who knows how to do it.
If you can't find an adapter, look for a tranny that will bolt up to the 302 and throw that in there at the same time.
Hope this helps!
Old 05-16-2004, 09:13 AM
97chevyman's Avatar
97chevyman 97chevyman is offline
i would personally stay with the triton, but i do things people don;t understand so i will try to help. Would will need a different tranny, an AOD would work nice because would would not have to worry about the computer stuff. I think the 5.4 makes more torque and horsepower than a stock 302, but you could build a mean 302 and throw it in there. You will need different motor mounts, tranny mounts, and the diff will work.
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
