View Poll Results: Should pontiac install pre outs(rca out for sub) in all radio/amp systems
Yes 7 100.00%
No 0 0%
If Possible 0 0%
Voters: 7. You may not vote on this poll
Old 05-04-2004, 09:37 AM
syqher syqher is offline
Send a message via AIM to syqher
monsoon radio edit
this one is complicated.... i have a new pon grand am gt 2004 with a monsoon stock radio. i want to install a box with 2 subs and one 600w amp, im aware there is already a amp in the drivers side trunk but i need the proper specs to get this radio installed. i need a seperate 12v for the amp and there needs to be a connection to the rf,rd and lf,lb channels the rest may be left allone. if there is a wireing diagram i can use that would be helpfull.
Old 05-04-2004, 09:58 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: monsoon radio edit
Wire the new amp seperate , if your gonna use a inline speaker wire for rca signals to the amp for the subs then use the speaker wire before goin to the monsoon amp and make sure its the low ohm wire your using , you dont want highs for bass, the 12 volt could be straight from the battery or empty/aux fuse holder on the + then use a switch inline with the 12 volt wire so you can turn the amps on and off , thats since you dont have a remote on that monsoon deck that way you dont have to take a chance damaging the deck.
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 05-09-2004, 12:21 AM
ummm?
i dont really understand what all that means so if u could please explain in a more simple manner or if someone could "explain" what was just posted... thank you
Old 05-10-2004, 03:12 PM
gebster76 gebster76 is offline
It means "take it to a proffesional and pay the $50.00 bucks to have it done right."
Old 05-10-2004, 03:17 PM
Jayman05 Jayman05 is offline
Send a message via Yahoo to Jayman05
i had a proffesional done on my car and yes you do need to take it to them. because there is so much you can mess up i tried i was too much so i too it to my buddies and they hooked it up.. i have 2 10's and 600wt amp.. so it's kind of the same but not really sounds sweet though
