Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 05-04-2004, 09:17 AM
kurimatzu1 kurimatzu1 is offline
starting problems
91 cougar 3.8 Hi, i recently have had problem where my car wont startup. Starter would sometimes make grinding noise when key turned but would start good run good. it wouldnt start in morning when wet outside today tried to start a few times almost fired but didnt, waited a minute or two then started after a few chugs and starts fine again thereafter. also been having bad gas mileage lately, tune-up parts have been done, battery is good, alternator, fuel pump few months old, fuel filter replaced. could it be a solenoid or ignition module or o2 sensor?
Old 06-01-2004, 11:41 AM
newman1983 newman1983 is offline
Send a message via Yahoo to newman1983
try cylonoid, and voltage reg.
try putting a new cylonoid, and voltage reg. if that isnt it. It could be your starter. If you have a new starter then i dont really know
Old 06-23-2004, 11:18 PM
furley furley is offline
Re: starting problems
MAP sensor could be disconnected. How about the spark plugs? If they are "fowled" the engine will be hard to start. Leaking fuel injector perhaps.
Old 07-05-2004, 01:07 AM
Laloma Laloma is offline
I'm having the exact same problem.. I had my starter replaced today and it still hasnt repaired the issue.
