Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 05-04-2004, 08:41 AM
amideutscher amideutscher is offline
back latch needs help to open
This is just annoying more than anything, I guess I should ask first off, is the hatch window designed to pop all the way open when you depress either button or turn the key? I have to push the button or turn the key, and simultaneously pull up on the hatch to open it (or at least in the next second or so). It is a 2001 Aztek. Like I said, it isn't a huge problem, just sort of... annoying.
Thanks!
-B
Old 05-06-2004, 07:55 AM
Mighty Quinn IV Mighty Quinn IV is offline
Banned
Re: back latch needs help to open
Thanks!
-B
And a very common problem especially when the weather is below 50 degrees. Check out the posts at www.aztekfanclub.com and you'll see it's not uncommon. There have been cures from making sure the rubber stripping is not sticking to auxilary springs on the latch to new struts to adjusting the rubber buggy bumpers under the hatch. I've learned to live with it leving in Cleveland, Ohio
Jack
01 Red Tek
Mighty Quinn IV
Senior Moderator Aztek Fan Club
PS come on over and join a Aztek friendly site and join us June 18-20th in Sandusky for the first annual Midwest Aztek Rally
Old 05-06-2004, 08:41 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
There is a new procedure for fixing this problem. GM came out with a TSB on it, it has several adjustments to do, I have done one so far with no further problems.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 05-06-2004, 09:29 PM
Banned
What is the number for the TSB
Jack
Old 08-02-2004, 11:58 AM
big dave's Avatar
big dave big dave is offline
back latch
I just backed the bumpres out two or three turns and it seems to have fixed the problem.
Big Dave
Montana & Aztek fan
