Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-04-2004, 02:19 AM
blackbird24 blackbird24 is offline
Question Front Differential Hose
Hi there,
I have a 93 JGC 4.0L. While I was removing my air filter housing I noticed a hose that was not attached to anything. I followed the hose down to the front differntial housing. What is purpose of this hose? Is it suppose to attach to something in the engine compartment?
Old 05-04-2004, 05:18 PM
Dale Aeppli Dale Aeppli is offline
Re: Front Differential Hose
Originally Posted by blackbird24
Hi there,
it's a air vent for diff. venting should have a little white vent on it
[email protected]
Old 05-04-2004, 06:07 PM
Re: Re: Front Differential Hose
Hi Dale,
Thanks for responding to my thread.
Do you mean the end of the hose that resides in the engine compartment should have a vent on it? Should the hose be fastened to something in the engine compartment?
Al
Old 05-04-2004, 06:51 PM
Re: Re: Re: Front Differential Hose
Hi Dale,
Al
hi, theres supposed to to be a white vent fitting that just pushes inplace alot of times they tie the open off to the side so nothing goes down hose [email protected]
Old 05-05-2004, 11:08 AM
leowolf leowolf is offline
Re: Re: Re: Re: Front Differential Hose
Just touching up... the hose is to keep water out of the differential when you decide to cross a stream or what ever or when you launch a boat, (theres one just like it in the rear housing). Dale is saying that there should be an instert in the end of the hose, (my isuzu didnt have an insert)..just make sure the hose end is up high in the engine compartment and if there isnt an end on it, get a cheap fuel filter and clamp it to the end of the hose (if your dealer doesnt have the original). this will keep the differential from getting an crud in it.
Leowolf
Old 05-05-2004, 11:21 AM
Re: Re: Re: Re: Re: Front Differential Hose
Hi Leowolf,
Wouldnt the fuel filter act as a plug defeating the whole breathing process altogether?
Thanks.
Old 09-15-2004, 02:38 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
the vent hose on mine(94 Grand Cherokee 5.2) is attached to the side of the Air Cleaner box. u will c 3 lil click u just push the hos into
