I have had some suggestions to get a pair of pacesetter headers and they have a damn good price. Why are they so cheap compared to others such as slp, hooker, jba etc? and should i get a Y pipe along with the headers? and what is the difference between offroad and normal y pipes cause i only can find off road y pipes for the pacesetter headers.
Re: Pacesetter Headers?
also should i spend the extra buck for ceramic coating? and can i get a different Y pipe with high flow cats to go witht he pacestters? im confused on what i should do with the whole y pipe situation
Re: Re: Pacesetter Headers?
I run pacesetters. They work great! I would opt for the Ceramic coating on the headers, it will help a lot against heat/corrosion/etc. My Ypipe is painted(which is how the headers will come if you do not get them ceramic coated. if you do go with painted, sand blast off the paint and go to autozone and get the 1500 degree paint and paint both the inside and outside of the headers(along with the ypipe). I bought my headers from Texas Speed and Performance. It came with a ypipe, O2 simulators(for the rear 02s), O2 sensor extenders(for the front O2 sensors) as well as new gaskets(I reused the MLS gaskets that are stock...and yes, they are reuseable) and bolts. Only thing about these headers, are you have to cut about 1/4" off your Kmember to keep the header on the driver side from hitting. I put them on my car myself...and they are an easy install. Passenger side slide right in(couldn't do that with FLP,SLP or Macs). Drivers side, you have to unhook your steering shaft(takes a whole 3 minutes from unhooking the shaft,slidding the header up and rehooking up the shaft) Its either that or your oil filter...sooo...I felt it was a good trade off. Install is really easy, just a little time consuming. Only bad thing about the ypipe(its freakin' huge...3") is 1. Make sure you take it to a muffler shop to fit up the left and right sides. Mine did not come flanged out on the right side so it would not slide over for an easy fit. 2. You might have to have it heated up and bent slightly if you do not like it tapping the floor under a "bogged" takeoff. Other then that, for the price of the pacesetters you can't beat them. Call Robert at 405 721 2430 for pricing and ordering.
DarkblueTA GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit 2007 Nissan Titan Daily Driver. 2* advance
that is an off road ypipe ur talking about right? does that mean it will not pass emisions? and i def dont have the skills to do the install myself do you have any idea where a good shop to get all the work done would be? i live in new jersey but anywhere in PA would be find too.
Would northern DE be ok, say Newark?? I might have a friend who may be willing to do the install for you, I would have to call him though. Not sure what he would charge. AIM me sometime. I am putting a set of carsound cats on my car, not for emissions, but to quiet the car down. Its pretty damn loud and I want to try to keep the 'sleeper' status.
awesome that sounds great yea i have ur sn on my buddy list ill IM you sometime. i need to make some money this summer before i buy anything but how much do you think it would cost for everythng. The headers, the ypipe, the O2 sims? and what aboutt the install price. that is great if u could get someone to do it becasue i only want someone who really knows what they are doing to install them and im assuming this person does consdering your own recognition.
670+shipping includes *Long Tube Headers that are Ceramic Coated *3" Off Road Ypipe *2- O2 Sims *2- O2 sensor extenders *gaskets/bolts(just reuse the stock header gaskets) take 100 off for the Ceramic coating. As far as labor, I'll see if I can't call Dan tomorrow(today?) and see if he could do it for you. I might need your phone number and name to call you if you agree to it? ok. Let me know if this is acceptable. If he can't, I'll let you know and I'll try to ask around for a good shop.
OK that sounds great...damn that is a really good deal. But i wont have the money to get them for about 3-4 weeks so no need to rush into calling your friend. if he can do it that would be great though cause i dont wanna pay some dumbass who doesnt know what he is doing and mess everything up. oh and you have a ls1 engine or an lt1 im assuming ls1 cause u have the p1sc procharger.
by the way whats some of your 1/4 mile times? |
oh and do i want the headers that say wity smog or the ones that say smog?
I talked to my friend Dan. He said whenever you want to do it, let me know and the 2 of you will work out a day/time. I have an LS1 engine(98 TA ) With a slipping stock clutch on 6# of boost(old pullies) in Texas heat(high 90s/low 100s) I ran a 12.9@112 with just the blower and a muffler(stock programming, running an FMU to boost fuel pressure). I ran at Atco NJ(I hate that track) back in September 03 with the same setup and ran a 12.7@115 spinning through 1st and going 45* sideways on the 1-2 shift. what fun. But it would have been a nice low 12 second pass if I could have got traction and not gone silly on 1-2 shift. Its ok though. I am waiting to get VCM Edit via HPtuners so I can program the car on the street with a wideband O2 sensor.
If I were you, I'd get the smog headers for your car(the same year as your car). If you end up eliminating the EGR or AIR systems, you can just add blockoff plates, it takes a few minutes for each.
how much for the 1500 degree paint and is it something i could put on myself?
98 Chevrolet Camaro
1200-1500 pait is like 8.00 at autozone. do you have an open area to do it at and a steady hand? if yes to both questions, then you can do it.
ok thats awesome. i have your aim sn so i will keep in touch with you on there or on here. so we both got a 98 TA...sweet.
