Old 01-14-2002, 11:35 PM
clos1428 clos1428 is offline
Send a message via AIM to clos1428
Angry door lock is being stingy..
- just wondering if anyone has taken apart the doors of the VR-4...is it a pain in the ass to do??? I have to fix the lock on the drivers side it doesnt want to work sometimes. Thanks for the help.
Old 01-15-2002, 01:46 AM
one more thing....
-sorry to ask another question but im the new guy so bare with me...i have a '91 VR-4...i was recently informed that they should boost about 8 or 9 psi stock...im boosting about 14psi...is it possoble i have a manual boost controller already installed??...Where should i look for it?? Thanks again...
-carlos
Old 01-15-2002, 12:02 PM
VeilsideVR4 VeilsideVR4 is offline
The door is very easy to take apart, there are a few screws on the inside panel, thats it. Ignore the stock boost gauge, it always says 14 psi, it is not accurate at all. You should install an aftermarket gauge to get the correct boost readings. If you are stock then you are pushing around 9 psi I believe, 94 and up VR4s push 12 psi stock.
IZ
3SI # 1187
Old 01-15-2002, 04:21 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Yeah. What VeilsideVR4 said. Also, once you have an aftermarket gauge and controller you an safely go to 14psi (and a bit more if you'd like) without having to change your fuel system.
Resistance Is Futile (If < 1ohm)
Old 01-15-2002, 10:12 PM
Cool thanks...
thanks for answering...i fixed the lock i just sprayed some WD-40 works like new...and i will be buying a new boost gauge soon so thanks. Now i know the stock gauge reads 14..but it actually goes up to 14, is it really that inaccurate?
