Old 01-14-2002, 10:55 PM
DropSquadCivic DropSquadCivic is offline
Send a message via AIM to DropSquadCivic
Unhappy HELP! How-To put a B18c1 into a 88-91 civic DX
I 'm not sure of everything I need or need to do to get the motor running for the swap like how-to get vtec running, what axles, do i have to reweld the mounts, how do i wired up the motor, cabletranny to hydro and so forth the very important stuff for the swap. If N E one can help me it would be mucho appreciated. THanks a lot
Old 01-18-2002, 09:16 AM
92 Teg-B18A's Avatar
92 Teg-B18A 92 Teg-B18A is offline
sorry I have no clue as to how you would perform this swap. But I do know this, you will more likely than not have to relocate some engine mounts. The parts you'll need are the engine, Tranny, flywheel, clutch, axles and ECU. You need to get the ECU that match's the engine your putting in your car because it is what controls the mighty Honda VTEC!
Hope this helps, but for more of a detailed and well probably better answer than mine try posting in the JDM Motor & Parts info/chat Forum (it's also for engine swaps too) if this thread isn't getting you anywhere!
If you decide to do this swap I know you're gonna have a rippin little car!
92 Acura Integra RS
B18A is the bizzam
PH refugee
AF Nordic Crew #004
Warning: The Surgeon General says it's OK to smoke V-8's.
Old 01-26-2002, 06:54 PM
eghb eghb is offline
motor swap
i can get you all you need for your swap. where are you located?? if you are local i can do it for you. if serious hit me up [email protected]
