Old 05-03-2004, 06:17 PM
dsmodder dsmodder is offline
Send a message via AIM to dsmodder
diff between 95 and 97
anybody kno the differences between a 97 and a 95 eclipse. i got a 97 gst and im sellin it for a 95 gsx. i kno the body is different a little but is the inteirior the same? i got a custom box in my 97 for 4 twelves and need it to fit in the 95 are hte trunks the same?????? a list of differneces would be good
Old 05-03-2004, 06:22 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: diff between 95 and 97
best way to tell is to try it tell us whether it works
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
amdsoldier amdsoldier is offline
interior is the same
Although seeing many 95-96 it seems to me perhaps the passenger side airbag fits slightly better than the 97-99. Again from what I've seen the 97-99 ones seem to have that cover sticking out ever so slightly, but lol other than that nothing really.
And yeah I'm in the same type of situation! Have a 97 w/ 6 10" subs and will be transporting it to a 95 model as well.
Old 05-03-2004, 06:44 PM
Reckage Reckage is offline
I just wanna ask what the reason is for selling a newer version for an older version just curious???
Old 05-03-2004, 08:12 PM
Re: Re: diff between 95 and 97
Well it's not really much of a downgrade to begin with. Since the car I'm buying looks exactly like a 97-99 model, except it's cleaner than most and with less milage.
But the real reason is because it's an GSX vs my RS.
Old 05-03-2004, 08:26 PM
ok ok i thought You guys already had gsx's sorry my bad
Old 05-04-2004, 02:27 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
should fit fine. ps, now you'll have the eprom ecu, so go buy dsmlink.
Old 05-04-2004, 02:59 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
So all the 2g GSX's and GST's have the eprom ecu?
Old 05-04-2004, 08:41 AM
nova1313's Avatar
nova1313 nova1313 is offline
no just the one year i think. I believe the 95's did......... it's in the faqs at the top of the forum.
Old 05-04-2004, 09:15 AM
95GSTRaCeR 95GSTRaCeR is offline
Most 95's came with the eprom ecu, easiest way to find out is to take a look. I believe I read somewhere that even though it may say it on the cover of the ecu, it still may not be, open it up and take a look, I believe in the faq it tells you how to tell the difference. Be carefull not to strip the screws on the housing, I dont know why the torque those things down so much...
Old 05-04-2004, 11:56 AM
#MD312464 e2p61672 5225 E
#MD309947 e2t61674 5111 E
E is the big thing at the bottem, some have "T"
thier are 8 diffrent ecu's from the 95 dsm that will work. those are the only 2 i know off hand.
Old 05-04-2004, 11:58 AM
i kno the headlights are different from 95-96 to 97-99 but do you guys know if they share the same bolt pattern. i mean can i just swap some 97 headlights into a 95 with no fabricatoin? im gonan buy this nx widebody kit that includes new fenders and quater pannels so i think the outside will look like a beefed up 97 basically. the hatch on the 2 models is the same right? i kno the body doesnt have as much of a curve look in the 95 and 96 where as the 97-99 had more curves in the rare quater pannels.
the nx kit is on www.bodykits.com
Old 05-04-2004, 12:12 PM
not sure, what to the aftermarket headlights say they will fit? 95-99? 96-99?
