Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-03-2004, 03:32 PM
RSW RSW is offline
head gasket
I've got a 92 integra and I'm about to change my head gasket for the first time. Any suggestions or useful tips to make it easier? Thanks!
Old 05-03-2004, 06:10 PM
IntegraB16 IntegraB16 is offline
Re: head gasket
Make sure you re-torque your headbolts to the suggested spesifications, along with making sure you put your cams and timing belt in right. There is more to it, Thats just the obvious stuff.
Old 05-04-2004, 04:09 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: head gasket
Go here and download the manual. Click on the link at the top that says icelord.net. Make sure you loosen the head bolts in the right order and make sure you re-torque them in the right order as well. Basically do everything word for word that the manual tells you to do. DO NOT take any short cuts!
Old 05-05-2004, 01:53 AM
scallywag scallywag is offline
Re: Re: head gasket
Ya re-torquing your bolts right is important. When I got my car, someone had recently replaced the head and they didn't torque them to the right setting,and I ended up cracking the headgasket. And do make sure you do your water pump and timing belt at the same time. It will save you alot of work later
