Old 05-03-2004, 02:31 PM
superblur superblur is offline
Question 5.0 mustang crate engines
I was just wondering what size crate engines fit in (by fit iin I mean directly bolt up to) the 5.0 mustangs(years 86-93) and what is their horsepower rating, and price if you know it?
Thank you for your time!
Old 05-03-2004, 06:43 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Well the only direct bolt in is a 5.0L. A 351W will bolt in motor mount and tranny wise but you'll need all the accessories, etc, etc to make it work.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-03-2004, 09:06 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: 5.0 mustang crate engines
a 351 Cleveland will also bolt up, but its the same deal as with the 351w, you'll need to get all the cleveland specific accessories(p/s, alt, headers, etc)
Old 05-03-2004, 11:38 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
you can find stroked crate motors that are based on the 302, 331 and 347
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 05-04-2004, 02:01 PM
Thank you! All three of you!
Can you guys tell me what the hp rating is on the 351w and 351c (Cleveland).
Thank you
Old 05-04-2004, 05:51 PM
just check out websites like www.enginefactory.com - outfits like these are a wealth of information.
free hypsi87!!
Dan's White Horse
Old 05-04-2004, 07:41 PM
duplox's Avatar
For stock, the cleveland is higher powered... 351w was a truck motor, the cleveland came in Mustangs including the Mach 1, and the Cleveland's heads fed the legendary Boss 302. With headers, cam, intake, carb, and new gear in the heads, 450hp is easily attainable. I know one guy who ran a cleveland with home ported stock heads, stock crank(even stock main bolts..) and prepped(shotpeened and polished) stock rods, stock block 1/2 filled with Hard Blok, cam/intake/headers in a 2845# wet '69 fastback that went 6.18 @ 110 in the 8th, which should give around a 9.8 1/4 mile time. The car was set up for 1/4 mile racing. If you want, I can send you the whole story on the build.
Clevelands were made for racing... Ford verifies that the Cleveland series (and direct derivatives) has won more championships than any other Ford engine type. However, the 351w has a whole lot more aftermarket than the cleveland, so it might be cheaper to build a windsor from a catalog.. But if you know what you're doing with a Cleveland(like KidV(who built the 6.18 1/8th mile engine) did) then you can make a whole lot of power for not a lot of $$, which is always welcome!
Old 05-04-2004, 08:19 PM
duplox's Avatar
By the way, I just looked up the figures on the '71 Boss 351: 330hp/370ft/lbs tq.
