Cigarette Lighter
The connection to my cigarette lighter is all out of wack. I wouldnt really care, but I have a radar detector, so this is why I have a problem. I dont feel like taking the dash apart, and Ive already bought another cigarette lighter. What can I hook up the new cigarette lighter to with out giving a large hassle, I just want my damn radar detector to work
Re: Cigarette Lighter
What year is your cavi? The older ones (up till 94-5, like mine) just use one screw by the lighter and ash tray and the center dash comes out. I don't know how the newer models come apart.
Other than that the lighters just unplug and screw out. they're about $4 at autozone/pepboys
Of you haven't broken it then you haven't gotten any use out've it. |
mines a 2000 ls 4 door
Try chcking your fuses. I got my cavi brand spanking new but for some reason the fuse was blown for just the lighter.
just splice the wire into the fuse box. cut off the cigarette adapter and put on a blade connector to put into an open spot in your fuse box and ground the other to a screw in the fuse panel
03, same thing
I have an 03 Cav, and I had the same problem. I don't know if the 2000's are the same, but i used my aux. lighter (near the passanger's feet) and just reached behind and hard wired it. It was very simple and took about 20 minutes... I had to use a switch, because the power isn't cut to the lighters when the engine and accesories are off. I don't know if your car is similar, but i hope this can help a little...
thanx for all the help guys
