Coolant Temp Sensor?
Are thier 2 Coolant Temp Sensors? and If So Which is the One that Controls the Guage in the car? and Where Is it located, i know about the one near the thermostate, is that the one? IN Dash Temp Gauge Doesnt Work. Would Buying another fix it, and why would the car not throw a code if the Guage isnt working?
Beware My Euro May Be After U! www.cardomain.com/id/euroguy026 The LUMINATOR LIVES On Intimidator (#3 Nascar) + Lumina = Luminator |
Re: Coolant Temp Sensor?
I asked the same question a couple of days ago and I had no response. I suspect it's one sensor, and replacing the gauge cluster would fix it. Post here if it does, or if you find the answer, because my gauge is funky too. If it is the sensor that's faulty the fan wouldn't come on at the right temp. No idea about a check engine code. I think the sensor near the thermostat is the one that controls both the fan and the dash gauge.
There are two sensors, the one by the thermostat talks to the computer. The computer turns on the cooling fans. The guage sensor is on the rear corner of the rear head, under the EGR valve
Thankyou
I couldnt find it but im gonna look again, but i had another question, thier is a clip or a plug that isnt plugged in, the clip is the same end as the O2 Sensor Clip the Male Part, its not plugged into anything, is there a purpose for that, ill look again near the rear courner of head
I Found it i see it, the wire is totally GONE, i guess ill try n find out how much one will cost, thankx u guys are awesome, OH and about my idle, its Fixed It needed an O2 Sensor
