Old 05-03-2004, 12:10 PM
godfather23's Avatar
godfather23 godfather23 is offline
HOW to put a model in a display case onto a wall?
Iīm thinking about putting all my models into separate display cases and then hang those onto a wall. The problem is that I canīt figure out a way to make those modells stick to the display case floor so that they donīt fall when I put the modell onto the wall eventually. I donīt want to put a screw into the chassis of the modell.
Please advise or give me some hints to solve this!
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 05-03-2004, 12:13 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: HOW to put a model in a display case onto a wall?
What? Are you talking about the display cases falling down? If so, Use a shelf?
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-03-2004, 12:14 PM
dag65's Avatar
dag65 dag65 is offline
Send a message via Yahoo to dag65
How about a small piece of double sided tape under each wheel?
Old 05-03-2004, 12:20 PM
nervestrikes's Avatar
nervestrikes nervestrikes is offline
How about drilling a small hole in one side of the clear display cover that a nail, hook, etc. can fit through, but be sure not to crack the clear plastic cover. Next because it is on display crazy glue the black base to the cover so it never comes open. Now you just hook it on the was like a picture. Done a buddy of mines like this and it looks great in his rec. room.
Old 05-03-2004, 12:31 PM
dag65's Avatar
If by crazy glue you mean Super Glue or CA that is a bad idea, as the glue gases out it will fog all the windows on the model as well as make all the fingerprints thtat might be there permanent.
If you actually read the post he is trying to figure out how to keep the model from sliding all over - not how to hang it on the wall
Old 05-03-2004, 12:34 PM
Sk8er6811's Avatar
Sk8er6811 Sk8er6811 is offline
Banned
Send a message via AIM to Sk8er6811 Send a message via MSN to Sk8er6811
tape is def. the best way to go, or use a lil bit of blue thumbtack
Old 05-03-2004, 12:35 PM
dag65's Avatar
Re: Re: HOW to put a model in a display case onto a wall?
Fun Tack dooohh I forgot about that, great idea
Old 05-03-2004, 01:52 PM
OOOH, I thought he was looking for something else. Curious how do you know there will be gas that would fog the windows. I never thought about that.
Old 05-03-2004, 02:01 PM
dag65's Avatar
Thats just the nature of CA, Law Enforcememnt Agencies have used a similar method to reveal finger prints for years. And I think it was not too long ago that someone here on the board glued a bunch of pieces on a model to complete it ( used CA ) and put it in a display case and set it on the shelf only to return to a disaster the next day.
Old 05-03-2004, 02:34 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
The best thing, I would think, would be that double sided foam tape 3M makes. It is very strong, but easily removable. Alternatly, if you want a classier solution that won't lift the wheels 1mm off the case floor would be to use a hook. Either form your own or get some small wire hooks that are bent 90 degrees (not a C shaped hook). Drill holes in the floor inboard of the lowest point on each wheel (or two of them). Then put the hook through the hole, with the 90 bend pointing out, and hook the wheels under them. This may take some finagling, but it's doable, and the best would be to use minature threaded rod and nuts, so you can tighten the hooks down and hold the car in place tightly. This won't require any modification of the model, and if you paint the hooks flat black, they will be invisible.
Old 05-03-2004, 02:48 PM
Macdaddy4738 Macdaddy4738 is offline
Send a message via AIM to Macdaddy4738
drill a hole in the bottom of the display case. Run a length of wire through the hole...around the axle of the model and back through another hole drilled in the bottom of the case.
Old 05-03-2004, 03:21 PM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
I have a few "Johnny Lightening" display cases that have a few holes for just this reason in the base.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
Old 05-03-2004, 03:26 PM
Wonīt work, tried it, not really sticky enough. I really need something working. I donīt want to repair my babies every week, because they re falling of the case floor.
That sounds like a great idea. I will give that a shot. Thanks a lot. If that doesnīt work, Iīll go with the axle solution.
Current Projects:
Old 05-03-2004, 05:48 PM
soldsep soldsep is offline
is the case floor not leveled? i dont understand how they are sliding around.
Old 05-03-2004, 05:52 PM
Sk8er6811's Avatar
Banned
me either
