Old 05-03-2004, 10:49 AM
bbordt bbordt is offline
Send a message via AIM to bbordt
Question S-10 Stalls when hot
I have a 91 S-10 pickup V-6 that runs fine most of the time. After you run it on the highway it will stall as you are slowing down. I can pop the clutch and it will restart. Around town it seems to be fine. It only happens when you are slowing down. It will idle fine too! It just had a tune-up. All filters were replaced. Any help would be appreciated.
Old 05-05-2004, 10:05 AM
83XFIRE 83XFIRE is offline
Send a message via AIM to 83XFIRE
Re: S-10 Stalls when hot
Just down shift to slow down. You have a manual, use it. You will save on brakes then too. Other than that check the idle sensor, or adjust your idle a smidge higher, just to keep it going at those points where it stalls.
98 Chevy Zr2
00 Yami R6
Old 05-12-2004, 02:12 PM
The problem turned out to be the air/smog pump. I picked one up from a junkyard for $25. It runs fine now
Old 05-12-2004, 05:29 PM
TopDogg TopDogg is offline
Maybe its the air pump given you problems.
