Old 05-03-2004, 10:02 AM
LittleGSEclipse LittleGSEclipse is offline
Send a message via AIM to LittleGSEclipse
Motor Mounts?
Whats up guys.
I need to know if I had a bad motor mount or transmission mount, could I buy just the rubber bushing or do I have to purchase the whole mount?
Old 05-03-2004, 10:26 AM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
whole mount
-Agim
Old 05-03-2004, 03:05 PM
soyee7's Avatar
soyee7 soyee7 is offline
Banned
Re: Motor Mounts?
can the actuall metal on the mount break, or is it just the rubber insert. what are the steps in replacing motor mounts on the 4g63 motor, i bought the polyurethane mounts for my car.
Old 05-03-2004, 06:12 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Motor Mounts?
http://www.turbo4wd.com/Mounts/MotorMounts.htm
Old 09-02-2004, 12:45 PM
jeffreyinigo jeffreyinigo is offline
Re: Motor Mounts?
hey dude i bought the prothane motor mounts but it doesnt come with any metal washers...what do i do to install the inserts into the front motor mount?
thanks
Old 09-02-2004, 03:42 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Motor Mounts?
Just stick em on there and put it back together. If you can put gas in the car, you can do the front insert. Some kits dont use washers. I have the extra hard old skool prothanes, no washers.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-02-2004, 04:40 PM
but wont they move around alot?
i thought that something else would need to go in them since they do seem kind of small and seem lke the mounts dont fit flush into the motor mount.
Old 09-02-2004, 07:35 PM
AF - Advisor
Re: Motor Mounts?
It works, trust me If the old mounts fit, and these ones dont sit flush, they should be even tighter fit. Right? Give it a shot, I'll bet its good. I need to lube mine up to assemble the front mount, no washer needed.
Kevin Jewer
Old 09-02-2004, 09:15 PM
cool dude thanks a lot. i just think i found the solution. the prothane motor mounts insert into the rubber. right?
Old 09-03-2004, 05:38 AM
AF - Advisor
Re: Motor Mounts?
Yes, they are molded in a shape that will fill the gaps in the stock rubber mounts.
Kevin Jewer
Old 09-03-2004, 02:58 PM
Re: Motor Mounts?
thanks dude for all the info....i just put them on the car and they work awesome.the car had a little more jump and the accelertaion improved......the old motormount was completely broken......thanks a million man
