Old 05-03-2004, 06:05 AM
Dopeness Dopeness is offline
Send a message via AIM to Dopeness
302 upgrades...
My pops gave me his old 73 Mach 1 Fastback (with the cool sportsroof) but out of respect for him I don't want to change the 302 it came with. Does anyone know the HP the stock 302 has for a 73 Mach 1?... and can anyone give me ideas on what I can add to it to increase the HP, aside from adding a supercharger?
Old 05-03-2004, 07:16 AM
Tony H Tony H is offline
210. If you'd take it to a dyno right now you'll likely see a lower #. when you say change you mean you dont want to swap in another motor, right?
Old 05-03-2004, 11:45 PM
Re: 302 upgrades...
So 210 is the HP right?... oh and what's a dyno?... and yeah I mean I've been told to swap to a 351 but i don't want to... and thanx for the info.
Old 05-03-2004, 11:48 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: 302 upgrades...
The dnyo is what you use to find out what horse power have. you can have a chasis dyno or at the crank.
Old 05-04-2004, 12:09 AM
Yea, its rated at 210 hp, if it was tested with a dyno it'd be a little lower. I think in 72 they went from messuring the power from gross to net. Net is what you have after all is said and done going to the wheels.
Old 05-04-2004, 01:58 AM
scla90044's Avatar
scla90044 scla90044 is offline
Send a message via AIM to scla90044
Old 05-04-2004, 08:38 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: 302 upgrades...
Actually the 73 Mach 1 came standard with a 302 2-bbl, that was rated 140 bhp at 4000 rpms.
There were other motor options for 73, such as the 351 2-bbl, rated 177 bhp at 3800 rpms, or the 351 4-bbl, rated 248 bhp at 5400 rpms.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 05-04-2004, 09:13 AM
Re: Re: 302 upgrades...
you're right. not sure where that came from now, must have been thinking about another year. I decided to look it up to be sure, according to this site, http://www.musclecarclub.com/musclec...istory-1.shtml , those #s you have are for 72, in 73 there were less engine choices
250 I6 95 bhp.
302 V8 136 bhp.
351 V8 154 bhp.
351 V8 156 bhp
lol, I was way off, sorry man
Old 05-04-2004, 03:57 PM
Any ideas on how i can upgrade the engine then without having to swap to a 351?
Old 05-04-2004, 04:26 PM
HiFlow5 0's Avatar
Stanger
Re: Re: Re: 302 upgrades...
250 I6 95 bhp.
302 V8 136 bhp.
351 V8 154 bhp.
351 V8 156 bhp
Well you are right about 73 having less engine choices, but those are the correct engines I listed.
72 had these for choices.
L-250 cid 1-bbl 6cyl 145hp
F-302 cid 2-bbl 8cyl 210hp
H-351 cid 2-bbl 8cyl 240hp
M-351 cid 4-bbl 8cyl (though may 1971) 285hp
M-351 cid 4-bbl 8cyl (Cobra Jet after may 1971) 280hp
R-351 cid 4-bbl 8cyl (Boss) 330hp
C-429 cid 4-bbl 8cyl (Cobra Jet) 370hp
J 429 cid 4-bbl 8cyl (Super Cobra Jet) 375hp
Now I think Muscle Car Club is a nice place, but I find from time to time that some of the info there isn't totally correct according to the books I have on specifics details.
-2013 Ford Flex
-1999 Ford F150
Old 05-04-2004, 07:17 PM
Ok, thats highly possible. I have some good books too but they are at home so I couldnt look it up in them.
Whats your budget? 302's have good potential. port and polish, valve job, better heads all together, new intake, 4bbl carb, headers, better exhaust, upgrade the ignition.
Old 05-05-2004, 05:58 AM
i have a budget of about a thousand... any ideas?
Old 05-05-2004, 03:41 PM
$1000 is kinda a tight budget, lets see cheap or free upgrades hmmmm.... If the engine is in good shape, consider switching to synthetic oil, it cost a little more but you'll pic up a few hp (not much mind you). Down side is that if you have a leak, synthetic will make it worse. They say to never break in an engine with synthetic.
My sure its well tuned and timing is right.
I'm not sure what carb you have and therefore no idea what it flows, but you can step up to a 2bbl carb that flows more. Are you could get a new 4bbl intake and a small 4bbl carb (I say small because if your heads arent upgraded) . A more agressive cam but this is a bigger job.
I would start out with a set of headers. duel exhaust
heads can be expensive, but you may be able to do something with the valve train. You can take your stock ones off and port and polish them yourself (or if you dont feel comfortable get a machine shop to do it).
If it were me, I'd do the exhaust, port the heads (or you might be able to hunt down a cheap set somewhere), and step up the carb. It should be a good improvement.
Old 05-05-2004, 08:47 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: 302 upgrades...
Cam/Carb/Intake/Exhaust/Windage tray, and port and polish the heads yourself. If you do your research and match your parts well, you can gain a lot of HP.
Old 05-10-2004, 01:45 AM
scla90044's Avatar
How do you do the port n polish yourself, what tools do you use?
