Old 05-03-2004, 12:13 AM
violator6090 violator6090 is offline
Question New Tires?
My tires are startin to lose their traction and i want new ones. Since i am going to get new ones should i may as well get ones that are a bit wider than stock? or should i get ones about the same size just good tires? Any suggestions as to what tires i should get? i have a 98 trans am automatic with 3.73 gear ratio exhaust and hypertech power programming. i plan to eventually do alot more and have my car over 500 horsepower so should i just go ahead and buy wide tires? Oh and i know the stock tire size is 245/50/16 what does the 245 represent and the 50? i knwo the 16 is rim size?
would you suggest either of these tires?
http://www.tirerack.com/tires/Compar...g=ZR&x=17&y=13
Old 05-03-2004, 04:35 AM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
Re: New Tires?
I have the KDWS...but what that link goes to is a 255/xx/17" tire. you want a 245/50/16 tire...and trust me...you'll be fine until you get in the high 300rwhp mark
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
Old 05-03-2004, 10:59 AM
Re: New Tires?
yea i wanna get 17 rims too thats why i increases it to 17 and if im gonna spend the money why not just get the 255 that is wider right?
Old 05-03-2004, 11:23 AM
nmn54 nmn54 is offline
Yes, I would say definately. I bought my car with tires that needed to be replaced. So when I went I called the tire place and got a quote and got somewhere around the money they said. Anyways, my tires were wider than the stock tires, and I switched back to the stock size. Now, when then streets are wet and I'm stopped and if I accelerate somewhat fast from a stopped position, I will spin my tires and I don't get any traction, so my opinion is yes.
