Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 05-02-2004, 11:16 PM
Mr2_bOi Mr2_bOi is offline
91 mr2 turbo apexi bov problem
i have just purchased a used apexi bov the noise is ok but the problem is the poping noise from my exhaust. when i first got it there was no problem its been a couple days now and noticed there was more boost and not much turbo lag but its eating up a lot of gas and when i switch gears theres a pop outta my exhaust. i think the combustion timing is off or somethin. just wanna kno if i can fix it by tuning the bov pressure setting the screw u can turn with an allen wrench. please help. thx.
Old 05-03-2004, 12:03 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: 91 mr2 turbo apexi bov problem
Your BOV can not increase boost, so there is not boost.
Your exhaust is popping becuase of running rich, from the bOV.
The OEM vavle is the BEST performing valve you could possible have.
All other valves are expensive noise makers that rob performance and gas mileage.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 05-03-2004, 01:56 PM
scarecrowX scarecrowX is offline
Send a message via AIM to scarecrowX Send a message via Yahoo to scarecrowX
dude, email me at [email protected] and i'll show you how to get rid of the popping between shifts. it's really easy.
the majority of the MR2 community is just gung ho about the stock valve. truth is, there's nothing wrong with aftermarket valves if they're set up properly. the bypass feature? don't you think if the bypass feature was so uber-important to toyota engineers, they would have placed it closer to the tb so the engine didn't still have to try to breathe through the second largest restriction in the intake tract (the intercooler)? just how much "performance" do you think that's worth?
Old 05-03-2004, 02:16 PM
AF - Advisor
scarecrowX, the tone of your post says a lot.
You want to tell "the truth".
The truth is, there is no aftermarket valve that will give you more performance than the OEM unit.
So why waste money on one?
As for how much performance do I think it's worth? I think my performance numbers speak for themselves.
There is only one aftermarket valve that shares the OEM's air-based design and that lacks the by-pass feature. All of the spring-type BOVs are inherently flawed. They have only a limited range function.
Old 05-03-2004, 02:49 PM
how can i stop my engine from running rich and does a recirculating bov that recirculates back into the intake better than the one i have now? i guess its not more boost but seems like turbo is spooling up faster like around 2300 rpm and not much turbo lag but the gas is killin me cause in san francisco its expensive here
Old 05-03-2004, 03:01 PM
AF - Advisor
There are several reasons you could be running rich.
1. You are blowing off air the was metered by the AFM. Re-circulating cures that.
2. If your valve is opening under boost, which is highly probable, then you are blowing out metered air again.
3. Your gas mileage will also suffer from not having the by-pass feature of the OEM valve. No aftermarket valve offers that feature.
Old 05-03-2004, 03:03 PM
AF - Advisor
** side note, I have some healthy horsepower coming out of my car and I regularly get over 24 mpg. My car is tuned and I do use the OEM valve.
I got rid of the AFM, so my OEM valve is vented to atmosphere so I have the "noise". You should only do this if you have a VPC or stand alone engine management.
Old 05-03-2004, 03:14 PM
would u recommend any aftermarket bov that has almost the same feature as an OEM valve but not have as much drawback as the apexi bov.
Old 05-03-2004, 03:24 PM
AF - Advisor
There is one that HKS makes (not sure which model).
It has the exact same air design as the OEM unit, so it responds just as fast and recirculates air ... it only lacks the by-pass feature (which is the least to be worried about).
Old 05-03-2004, 07:00 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
the HKS one is the same style as stock, but uses a 2 part opening, and thus reacts faster.
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 05-03-2004, 11:17 PM
the "truth" is, you are basing performance on a bpv, which is an inherently flawed argument in itself.
as do vince F's. i believe he is #1 on the 1/4 mile registry and i distinctly see in his engine bay an apex valve- the very one you're saying isn't capable of the same performance as yours.
anyway, that's beside the point. the point is, he ALREADY spent the money on one. i'm here to tell him there IS a way to make it work, even with the stock electronics.
Old 05-03-2004, 11:34 PM
AF - Advisor
Now that is great point.
Because someone already spent the dollars on an inferior product, you are offering to help them make it less inferior. How noble of you. I would rather help them do things for the best performance.
That's just me.
Vince has a race car.
I have a street car that sees a variety of racing venues.
I am sure Vince could care less about the by-pass function since he only drives at WOT and would never use it.
I am sure Vince could care less about the spring only being ideal at a certain PSI since he races at a specific PSI. It's not like he needs it to sometimes open at 10 psi and other times at 35 psi.
Now if the original poster is indeed building a dedicated drag car,
I stand corrected and I apologize for not allowing for that possiblity.
Old 05-04-2004, 02:00 AM
is the hks one the super sequential?
Old 05-04-2004, 02:08 AM
wow jek, you're right. the rest of the automotive community could not possibly know what they're talking about...
*rolls eyes*
since my points are still valid, i'll just leave it at that.
Old 05-04-2004, 06:22 AM
AF - Advisor
Mr2_bOi, I believe it is the super sequential.
Just make sure the one your buying doesn't have a spring in it and you'll be fine.
Incidentally, if you want another unbiased view on this topic, you can read this article:
http://www.jekylhyderacing.com/bov.htm
It is hosted on my site, but I did not write it.
Bill, the author, is an engineer.
