Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-02-2004, 09:43 PM
gremlin_mischief's Avatar
gremlin_mischief gremlin_mischief is offline
Lighting problem - and rim fitting question
Okay, a few days ago I got in the car, started it up, and flipped the headlights on (twas dark out) - however, for some reason the speedometer lighting and rpm lighting, etc, didn't come on. Along with the lighting for the cd player and heating/cooling stuff. The digital gas and heat meters came on along with the clock. The next day I checked EVERY fuse, yes EVERY fuse and all were fine. That night, it all worked fine. Tonight, however, the lights once again did not come on. Does anyone know what could be wrong? Loose wiring maybe? If so, is it usually hard to find the problem infested wires, and fix them? Is there some way to go about it other than tearing everything out and looking for a loose wire? Any help is extremely appriciated!
Also, I wanted to get a set of rims for this car. The car's stats are the same except instead of the rims being the stock size of 15x6, they would be 17x7 (10 holes universal 5 holes), and instead of a bolt pattern of 4x114.3, it is 5-100/5-114.3. Does anyone know if those rims would fit on my car??? Thanks for any help guys!
Old 05-02-2004, 11:29 PM
crzyCollegeKid crzyCollegeKid is offline
Re: Lighting problem - and rim fitting question
it probably worked again because you reseated the fuse. try that again, but instead of messing with every fuse, try finding the correct one:
http://icelord.net/honda/repair/
if not...theres a short in one of the wires, and since you now know which wire and/or fuse could be the culprit, you'll have a much better chance of fixing it rather than checking every fuse and every wire.
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 05-03-2004, 07:39 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
97-01 Prelude, Vtech are 16x7 5x114.3. 17x7 would work fine. About the lighting. This sounds silly but is the knob that controls the brightness turned up?
Old 05-03-2004, 03:03 PM
Yeah, it's turned up . Thanks for the replies guys. I downloaded the manual off that ftp - it looks like it'll be helpful if it comes down to it. Thanks a bunch!
Old 03-27-2005, 06:01 PM
mccarthy155's Avatar
mccarthy155 mccarthy155 is offline
Re: Re: Lighting problem - and rim fitting question
Hey, i have the same problem with the speedometer and tach lights not turning on. Can you send me a working link for the site above, it doesnt seem to be working. thnx.
1993 Pimplude SR
