Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 05-02-2004, 08:34 PM
kjgirl17 kjgirl17 is offline
How do i replace the gauge lights?
The lights on my speedometer/odometer gauges burnt out so basically at night I can't see how fast i'm goin or how much fuel I have or anything. I was wondering if anyone knew how I could replace the lightbulb myself if u could help me out that'd be great. I just need to know how I'd go about getting access to the lightbulb itself. I'm not sure how to get that panel and stuff out... thanks
Old 05-03-2004, 04:16 PM
boschmann boschmann is offline
Re: How do i replace the gauge lights?
If all went out at the same time I'd check the fuse & wiring. What year?
Old 05-03-2004, 07:59 PM
Its a 94 I checked the fuse and its fine. Before the lights went out they were really really dim and now they just aren't working at all.
Old 05-04-2004, 08:06 PM
Have you checked the dash ligth dimmer rheostat ("switch")?
Old 05-04-2004, 09:28 PM
The odometer and clock are digital and are still lit up, when i tried checkin the dimmer switch it worked fine for the clock and odometer, but the speedometer and rpm gauges still have no light
Old 05-06-2004, 11:32 PM
If the other lights are working then it's probably the bulb over that gauge. You will need to remove the instrument cluster to get at it. The trim panel & various switches has to be pulled, then the speedo is held in by four screws. Before pulling it out you have to reach behind & remove the speedo cable & electrical connector. The bulbs are held in with twist lock plastic holders. It can be tedious the first time you learn to do it.
