Old 05-02-2004, 06:37 PM
sg4141 sg4141 is offline
headlight assembly
i purchased a set of the silver stars and i cant get the headlight assembly out can anyone help??????
Old 05-02-2004, 08:26 PM
justin0717 justin0717 is offline
Re: headlight assembly
year/model?
Old 05-03-2004, 04:06 AM
joshuajkelly joshuajkelly is offline
Lightbulb did headlight assembly tonight
I own a 1995 3.1 v6 grand am. I just bought a pair of those silver stars from gi joes [$50 ouch!] An it only toke me about ten to fifteen min. to install. I didnt even unbolt, unscrew or undo any thing. All you have to do is grab ahold of the actual part of the light that the wires go into the bulb and twist it about 1/4 of a turn and the bulb should pull right out of the headlight assambly. Then you just disconnect the wires from the bulb and plugin the new SILVER STARS and carfully put back into the headlight assembly and turn the opesit way you turned to take it out, and on the one that was on the right side of the car [as you are faceing the engine] you have to take of the black cover that has all of your coolent info. on it. It just unsnaps and pulls right out and you have your acsess to your headlight bulb. Hope it is as easy for you have fun and don't forget to write back se ya josh
