Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 05-02-2004, 05:27 PM
GENEMNC's Avatar
GENEMNC GENEMNC is offline
Send a message via Yahoo to GENEMNC
1998 Dodge Neon Won't Start Help!!1
i checked bat fuses
turn key all i get is tik tik but no turn over
f.f. g.lutz
Old 05-02-2004, 08:02 PM
Danijh1 Danijh1 is offline
Send a message via AIM to Danijh1
Re: 1998 Dodge Neon Won't Start Help!!1
your battery termal....take the postive off and then put it back on....tightly...
Old 05-03-2004, 01:42 PM
Ledgic Ledgic is offline
starter might be gone...I had that problem when the engine doesnt turn over at all
Old 05-03-2004, 05:49 PM
FuriousMachine95's Avatar
FuriousMachine95 FuriousMachine95 is offline
Send a message via AIM to FuriousMachine95
You might not be getting enough voltage to the starter. I know it is hard to get to, but try tapping on the starter while someone else turns the key, It might just be getting stuck.
Acting my age is no fun.....
Old 05-15-2004, 07:23 PM
GENEMNC's Avatar
it was the starter
but cost alot of money for part
down where i am
it was $198.98 + $80.00 core charge at advance auto
$150.00 + 80.00 core charge at napa
f.f. g.lutz
Old 05-27-2004, 10:58 PM
9neon5 9neon5 is offline
when i changed the starter in my 95 i had to unbolt the engine mounts and retate the engine to get the starter out. Ouch glad thats over.
Check out the N3ON
http://www.cardomain.com/id/9neon5
Old 05-28-2004, 10:42 AM
drag1320neon's Avatar
drag1320neon drag1320neon is offline
Send a message via Yahoo to drag1320neon
dead battery, starter or bad connection
you aint gotta like me, you just mad cause i tell it how it is, and you tell it how it might be
CHECK OUT MY CARS HERE!
drag1320neon and 209neon's babys < 209 neon finished!>
Old 05-28-2004, 05:08 PM
GENEMNC's Avatar
it was starter
f.f. g.lutz
Old 06-06-2004, 07:52 PM
Pedros91 Pedros91 is offline
Send a message via AIM to Pedros91
why on earth would u have to rotate your engine to change a starter are you guyz insane?????
Old 06-06-2004, 11:19 PM
Have you changed a starter lately?
Old 06-06-2004, 11:20 PM
If you have clue us in
Old 06-09-2004, 10:52 PM
Spudboy Spudboy is offline
Talking
Unbolt the engine? Are you nuts? All I do on my '95 is remove the frigging cooling fan... undo the ground wire, unbolt the battery holder strut, pull the two bolts at the top, disconnect the wire and wiggle it out. Then you can get at the starter no prob. PS. I have the "Y" engine...
Old 06-15-2004, 11:11 AM
