Finally Lowered
Re: Finally Lowered
Looks good!
Re: Finally Lowered
what springs did you go with? how much did you drop the thing, it looks a lot lower than mine. but then on the other hand i only had my stock wheels on for a day when i did so i didnt really focus on it enough to remember how much of a gap there was between tire and wheelwell. anyways.... LOOKIN GOOD Ripin...
if your looking for some wheels let me know... The kid i sold my old wheels to is thinking about selling them... 245/45/17 kuhmo tires (new) on enkie CDR-9s, click my link to check them out on my cardomain page if you want...
1996 Ranger with 249,xxx miles on it...
was my beater now my daily driver, still trying to figure out how that happened 99 MXZx 440 SNO PRO Forsale89' Honda TRX 250R ![]() |
Re: Finally Lowered
Thanks guys,
Im pretty sure I droped it atleast 2" if not alittle more. Havent measured it really, just dailed them down till it looked good and even. Took the car in for some body work so I only had 2 days to play around w/ the height. Where the front is now is as low as i can go without bottoming out on the speedbumps at my apt. complex. Overall the ride is very nice, very tight. Front; HELD coilovers 425lb spring w/ KYB struts Back B&G springs w/ stock struts |
Re: Finally Lowered
looks really nice. like the ride!
Re: Finally Lowered
Looks awesome sir. I like the way it makes your car sit. Looks very mean!!!! Where can the B&G springs be bought from? I want a set after seeing your ride.
Re: Finally Lowered
You can get the B&G's @ http://www.3800performance.com
But remember, I only have the B&G's on the rear. B&G's will not drop the front as much as you see in my pics. You'll need coilovers for that. www.heldmotorsports.com |
Thanks Ripn12s. 1.2" is plenty for me to help with cornering. I don't want to go much lower than that. That will be just about perfect.
Take care....
Re: Finally Lowered
How the ride feels? Did you got the bounce effect? That is what I would love to do the car next? Did it change the allignment setting much? Looks SWEET!!!
Re: Finally Lowered
The ride is real nice.
There really is no pogo w/ the coilovers, expecailly w/ the 425 lb springs. Overall ride is nice and tight, taking curves is real fun now w/ hardley any body roll compared to stock. Almost everyone w/ coilovers has complained about a slight vibration when accelerating from a stop and then again from 60 -70 mph. We think it is because of the huge drop possible and the fact that the stock axles have a different angle thus causing the vibration. I can release the wheel when driving down the street and the car continues going straight. I will be getting an alignment done and also new brakes. I think those 2 things alone w/ kill most of the vibration. |
Re: Finally Lowered
You think could get broken tranny terminals sooner because of this mod? How much did you spent overall? And let us know what happes after the wheel allignment.
Re: Finally Lowered
350 coilovers
110 b&g's 110 new front struts 003 cutoff wheels to modify the struts 005 spray paint |
Re: Finally Lowered
600 bucks and it looks great. I would like to see how the tranny terminals react to the lower hight and how the vibration behaves after the wheel allignment. Because if durability is basically the same and the vibration is barely noticeable it trully worth it.
I am asking about durability cause I met someone that did a very similar job lowering an I-mark and the only problem he had so far is that the tranny terminals really get all messed up rather quickly Last edited by kilroypr; 05-09-2004 at 10:30 PM. |
Re: Finally Lowered
You could lower it w/ just regular lowering springs. It wont be as low and there should be no vibration
Re: Finally Lowered
That is better and the springs are bolt on. Is that the roads around here are not that good and since I work on the road most of the time I need at least the same reliability that I have now.
Did you had a hard time installing the grills. I got them but the Idea of chopping down the screw lobes do not really excite me that much |
