Battery
Hi friends
Someone can help me , how can I change battery in the Montana 2000? Thanks Edgar |
Re: Battery
Not an easy task, but can be done. Remove the fuse panel from the croos bar, should be cliped on. The fuse panel (box) will only tilt out of the way, they didn't give alot of extra wire here. Remove bolts on cross beam and remove. Battery should be visible now. You will need a long socket extension to get the battery mount bolt out. Disconnect the battery. Once everything is unhooked you can remove the battery. Replce in the reverse order. Good Luck, Marty
