Old 05-02-2004, 01:29 PM
seco seco is offline
Banned
98 eclipse rs overdrive?
should overdrive be on or off?
Old 05-02-2004, 01:32 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: 98 eclipse rs overdrive?
keep it on
Old 05-02-2004, 01:39 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
on for gas mileage if you want to do highway races turn it off then your car will stay at a higher rpm at cruising speed and wont have to downshift when you floor it
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-02-2004, 01:48 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
If you are pulling hills and/or shifting often because of terrain, turn it off until you get back on a straight stretch. I can't remember right now, but whatever cools the transmissions turns off in overdrive, so your tranny will gain excessive wear from being hot due to lots of shifting.
