Old 05-02-2004, 01:23 PM
dubstyle714 dubstyle714 is offline
Angry anybody got an answer to this one?
ok, vehicle is a non-turbo eclipse 93, car overheated on highway a few days ago. got it towed home and pulled the head off, found a pretty tore up head gasket, so i replaced that and put it back together, was running decently for about 50 miles, now car still has water/antifreeze in oil but only leaks water/antifreeze when temp guage is up. any help would be greatly appreciated.
Old 05-02-2004, 01:41 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: anybody got an answer to this one?
did you torque your head on right? three stages from the inside to the outside so that it doesnt warp, very important with an aluminum head (which all t/e/l have)
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-02-2004, 07:55 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
Did you plane the head? It would have been warped.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 05-02-2004, 08:53 PM
Reckage Reckage is offline
did u say u have water in ur oil!!!!
Old 05-03-2004, 05:24 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Re: anybody got an answer to this one?
yea you shoulda checked that before you put it back on or your HG is just goin to go bad again!
Old 05-03-2004, 09:29 AM
it might not warp but you should have got it checked mine didnt warp or crack or anything after i overheated it baaaaaaad
-1stGenRocks-
Old 05-03-2004, 11:30 PM
I did torque the head correctly according to the chilton manual from the inside out, but did not heve the head planed, although it did look to be in good condition, since last post i traced a problem, one of the fans has gone out, so the radiator is only getting half cooling power, but that still dosent explain water in oil prob.
Old 05-04-2004, 12:07 AM
Talon007's Avatar
How did you check the head to make sure it was "fine"?
Chris Clark
www.Talon007.com
Old 05-05-2004, 04:35 PM
didnt say it was "fine", saud it looked to be in good condition because valves were not carbonized also head surface was clean, since then also the water in oil problem has been fixed by flushing alot of oil through engine, went to the junkyard yeasterday and bought some relays, which fixed the prob of bopth fans not turning on, but now neithe fan will turn on without relay being triggered so i am going to replace coolant temp sensor when i get a chance.
Old 05-05-2004, 08:59 PM
rollaracer94 rollaracer94 is offline
the case mite b that u have a cracked head or a cracked block... or like talon007 said mayb its just warped
