Old 05-02-2004, 11:49 AM
matt11583 matt11583 is offline
LT-1 vs. LS-1
what is the biggest difference between a lt-1 and a ls-1. i know that the ls-1 is a little faster but i want to know how much faster it is in a camaro. also, is one of them easier to mod that teh other.
Old 05-02-2004, 12:04 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: LT-1 vs. LS-1
well, to be perfectly honest, thats kinda like compairing a 2.8L to a 3.8L V6. the two engines are completely different other than the fact that they are both internal combustion V8's. so as far as compairing them, its pretty much apples to oranges. personally i think LT1's are trash, always have, probly always will. But the LS1 engines are awesome. from both a technological and performance standpoint. the LS1 is heads and shoulders above an LT1 anyday. just my personal opinion.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 05-02-2004, 01:02 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: LT-1 vs. LS-1
In a nut shell: LT1 is iron block, LS1 is aluminum, LT1 has a little more low end torque, LT1 yrs were 93-97, and LS1 yrs were 98-02.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 05-02-2004, 02:10 PM
Joseph1082 Joseph1082 is offline
Send a message via AIM to Joseph1082
Re: LT-1 vs. LS-1
LT1 and LS1 Torque is THE SAME, just that it comes up lower in the RPM band on the LT1, which might be an advantage I don't know, but the LS1 has a more steady power increase and better top-end, thus the higher HP rating and higher traps. But like said, the LT1 can most likely take a lot more punishment, if you were to go FI I'd definitely pick an LT1. Also, parts for LTs are cheaper, and so it will be a cheaper engine to build up. Also, correct me if I am wrong but if you build an LT1 to the same power as an LS! won't it perfrom better due to that Torque showing up earlier.
Old 05-02-2004, 11:03 PM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
Re: LT-1 vs. LS-1
Well no matter what you do to the LT1 short of forced induction, the torque will drop out at about 5200 rpm witch suckes monkey nuts no matter how you look at it. The LT1 might pull just a hair before the LS1 from an off idle launch, but at the strip or on the street who launches at Idle? So if you built the LT1 to match the LS1 then the LS1 will take it because it has about 500 rpm to spair.
Old 05-02-2004, 11:08 PM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
Re: Re: LT-1 vs. LS-1
I don't know about that. I drove a 98 Z28 that had been reprogramed with a high rev limiter and didn't seem like there was more pull at higher rpm than my 96 SS.
Old 05-02-2004, 11:11 PM
Re: LT-1 vs. LS-1
You don't always notice the high rpm pull that much from in the car. But side by side you should be able to see the differance.
Old 05-02-2004, 11:34 PM
89IROC&RS's Avatar
Re: LT-1 vs. LS-1
i would avoid the LT1 like i said, the LS1 engines are totally sound, shit lingenfelter is running twin turbos on em so FI isnt really an issue. the only weak link in the engines i know of are the piston rings, they have a tendancy to leak down and let oil into the chambers, so a set of aftermarket ones would be a must, but youd have to do em anyway on FI. but id trust the LS1 in all respects, performance, durability, efficiancy over the LT1 anyday.
Old 05-03-2004, 12:39 AM
Re: LT-1 vs. LS-1
But what about solid Iron vs. Aluminum?
Old 05-03-2004, 12:51 AM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
If you were going to highly modify the engine, then the LT-1 would be the best because of the Iron Block. The only advantage aluminum offers is weight.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 05-03-2004, 12:55 AM
dwrock1 dwrock1 is offline
Send a message via AIM to dwrock1 Send a message via MSN to dwrock1 Send a message via Yahoo to dwrock1
Re: LT-1 vs. LS-1
I would rather have an LT-1 but this is comming from someone who already has one
2003 Dodge Ram Quad Cab
Duel Flowmaster Exhaust
Horible Gas Mileage
Baby 4.7 287ci V8
Crap Automatic Trans
Pretty Wheels
Fake Hood Scoop
Old 05-03-2004, 02:17 AM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
Re: LT-1 vs. LS-1
Lt1's are an awsome engine for heavy mods and can take alot of punishment... however...the do have a MAJOR defect. the optispart (opticrap) if you have a highly moded engine the opti will prolie breakalot sooner. but i like the LT1's cuz their stron enough for a high shot of nitrous plus twin turbo and superchargers. LS1's are great engines too but i dont think you can getthat much out of it (unles its an LS6!! those are freakin AWSOME!!)
Old 05-03-2004, 12:42 PM
DVS LT1 DVS LT1 is offline
Big difference is the ignition - LS1 uses a reverse firing order and coil packs for each cylinder. Although the opti is actually a very sophisticated component as far as EFI is concerned, it suffers from a rather poor construction and horrible location.
The LS1 heads also flow more air than the LT1 castings. The LT4 heads flow numbers were closer to the LS1 head. Also, the LT1 engine uses a reverse-flow cooling system which sends coolant to the heads first (as opposed to last like the Gen I & III small blocks). Thats one of the big reasons the Gen II 350 LT1 was able to make 300 HP compared to the lowly 250 HP output of the Gen I 350 L98 - the reverse flow allowed GM to raise the compression ratio on the LT1.
Another related difference are the 28 lbs/hr fuel injectors found on the LS1 (vs. the 24 lbs/hr injectors in the LT1).
So basically, the LS1 benefits from more fuel, more air, and a better spark compared to the LT1.
An "easy" way or approach to mod the LT1 would simply be to address these inequalities - get an aftermarket ignition module and coil, port or switch to LT4 heads, and add larger fuel injectors. This not only levels the playing field but puts you in a position to really get the most out of other future mods.
Old 05-03-2004, 03:55 PM
Re: LT-1 vs. LS-1
I was saying, if you did exactly that, make it breathe better, whatever other little things need fixing, wont it be better than an LS1 because of it's torque coming up so low??
Old 05-03-2004, 03:56 PM
Re: LT-1 vs. LS-1
Shouldn't a 350HP LT1 beat a 350HP LS1 due to that fact alone?
