Old 05-02-2004, 10:53 AM
JAL JAL is offline
Brakes
Does anyone know, how many of the six items below MUST be replaced on both right and left wheels at once?
Drums, brake shoes, wheel cylinders
Discs, brake pads, calipers
Next question. 1990 3.1 Eurosport. The rear rotors LOOK welded to the hub! Even a former (certified) brake mechanic agreed when he saw it! I have applied a prybar with enough force to visibly bend the rotors on both rear wheels - won't budge, even with penetrating spray. The same prybar worked fine on the front rotors. Advice, anyone?
Old 05-02-2004, 02:07 PM
JAL JAL is offline
Well, it looks like I got one of the rotors off. Boy do I feel stupid. As for my first question, I will assume that it is safe to only repair one brake (one wheel) at a time, unless someone tells me different.
Old 05-02-2004, 10:28 PM
Taz202 Taz202 is offline
Re: Brakes
How did you get the rotor off? I had the same problem last fall. Finally a friend showed up, gave the rotor a good swat with a decent sized ball peen. Right between the wheel studs to be exact. The stupid thing popped off like it had just been sitting there the whole time.
Old 05-03-2004, 09:36 PM
JAL JAL is offline
Re: Re: Brakes
How? The grace of God I guess. The previous day I spent over an hour on it, using as my prybar a lug nut wrench (rather haphazardly in my impatience), and hitting everywhere with a hammer. No luck. The next day the same prybar dislodged the rotor within five minutes! I wonder if some type of jaw puller would have made the job easier.
