Old 05-02-2004, 01:34 AM
Taz202 Taz202 is offline
Unhappy rear brake problem on 90 3.1
I'm not sure what's going on with my rear brakes? I pulled the back wheels off and saw rust and scale built up on the rotors, but only on the outer half of the rotor. I new I had problems already and had asked a mechanic friend about it. He suggested the calipers where seized. I tried turning the rotors with the brakes applied and they seemed to be grabbing. Also if it is in fact the calipers can I take them apart easily and free them up or should I invest in new calipers?
Thanks in advance
Old 05-02-2004, 06:52 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: rear brake problem on 90 3.1
Thanks in advance
The slides are frozen. Not an uncommon problem on that body style vehicle.
The caliber is frozen in one position and the piston is only applying the inboard pad.
I would replace the calipers.
Side Note..there was a GM technical bulletin on this complaint with a set of special tools to remove the slides and hone the bore, but after 14 years it is doubtful that any GM dealers still have the complete set of tools to perform the repair
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-02-2004, 10:45 AM
JAL JAL is offline
Thanks in advance
I've had the same problem, and I heard a rumor that setting the parking brake regularly (minimum of once a week) helps to prevent the rear calipers from locking up.
Old 05-02-2004, 06:56 PM
newfslumina newfslumina is offline
Yeah sitting the parking brake at least a cpl times a week will save u hundreds of dollars in breaks....My last car was a Buick Regal . I had the same problem and costed me 1200.00 can. to fix. Learned my lesson since then with my Lumina
Old 05-02-2004, 10:21 PM
I appreciate the feedback, although I'm not sure I'll be using the parking brake any time soon. In the course of removing the first caliper I discovered that my emergancy brake pedal doesn't even work. The pedal still moves but the ratcheting mechanism must be broke.
Old 05-04-2004, 10:03 PM
bottomtech bottomtech is offline
Actually, GM was reimbursing people who had the same problems with their rear brakes a while ago. The caliper guide pins were originally stainless steel, which seized inside the calipers. Evantually the outer pad would fall out.
We still have all the tools to replace the pins, but you best bet would be aftermarket loaded calipers and new rotors, about $125 per side.
Applying the parking brake onlys adjusts the rear calipers. The parking brake lever rotates a screw threaded into the caliper piston, which will ratchet if there is too much clearance between the pad and rotor. This keeps the gap closed and the pedal high.
