Old 05-02-2004, 12:39 AM
19CENTURY92 19CENTURY92 is offline
Help Please Code 42
Hey guys I have 92 Buick Century and 91 Buick Park Avenue yesterday service engine soon light came on so I check it out and code 42 came up (Electronic Spark Timing) Few weeks ago same thing so I changed ingition module which is under coils. I restarted computer and everything was fine for few weeks until yesterday when the same code popped up.
Car keeps dying while I am driving it. I would drive it and all of the sudden it just dies out of no where. This stoped for a while when I changes this module but now it's doing it again. Please help me out!!
Old 05-03-2004, 11:34 AM
Opps123 Opps123 is offline
Re: Help Please Code 42
try changing the igniton coil , wires, and plugs give that a go and see how that works...
Old 05-03-2004, 11:54 AM
pcv pcv is offline
What size motor do you have in it? Code 42 will lead you to either bad wiring to ecm/module or components themselves. Drop the ecm, run the vehicle hot and tap the ecm with the palm of your hand and if the vehicle stalls, replace the ecm. If it's a 2.8L, more than likely that's your problem.
Good Luck.
NOTHING LIKE AN OLD CAR.
Old 10-19-2004, 02:51 PM
ken_m ken_m is offline
3.8l engine, could be the cam sensor or the crankshaft sensor also. I'd try the plug wires, etc first though. Try to buy lifetime guaranteed parts if you plan to own it for a while.
Old 10-19-2004, 02:57 PM
parkavenuechrome parkavenuechrome is offline
CODE 42!!! ok, it has to do with your CAM sensor, now here is the deal, In most cases its not the sensor that is at fault but the magnet that is attached to camshaft gear that passes over the cam sensor to give timing references to the ECM. no, you can be luck or you can be screwed and he is why i say this, they have 2 style cam sensor magnets that mount on the timing gear, one is a bolt on magnet that bolts to the timing gear, the other is a push in plastic housed magnet that the front of the motor has to be dismantaled and timing cover comes off, timing chain, etc all comes off just to replace the magnet. 500 dollars at a Biuck dealer.. happened to me.. the part cost 11.49.. go figure.. they was you know is, get a big mirror, take the sensor off, and crank the motor and look for the magnet, of you don't see it, then you have a project on your hands. Another glorious rocket scientist engineering by GM... Let me know.. The car will run without the sensor just will stall in some or run rich in others.
Old 10-20-2004, 06:07 AM
deadring deadring is offline
parkavenuechrome ,
i hope i don'T have the "inside the chain case you have to remove the front of the engine" type if mine ever dones break..
does it go by years or series on the 3.8? i mean do some years have that bolt on type and other years have the BAD one?
i wonder if the 92 pa has it the bad way?
Old 10-20-2004, 09:13 AM
It all depends on what was on hand at the time of manufacturing.. If any of you have the haynes manual you can see the different types and read about them.. I hope you don't have the one I had either.. expensive fix for a 10 dollars item.
Old 10-20-2004, 09:28 AM
well by murphy's law, i must have one.. it's inevitable ... my live evolves around it
i'll have to check
