Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 05-02-2004, 01:34 AM
sarsourus sarsourus is offline
Lightbulb Help with my sentra pleaseeeeeeee !!!
okay people wats up,
now i bought a nissan sentra gxe 92, ga16de with i guess b13?? now i upgraded my fuel system all hi performance, custom muffler from header to muffler, took off my catalic and resinator, hi performance brakes and calibers, not discs YET !!!, now i heard the sr20det from the SE-r fits my car but since i already did all this i thought of just keep going, now i got a good deal from a guy to custom my piston holes to larger rounds so i can try to fit either the skylines pistons or the SE-r's pistons, now since my car is automatic, is all the customizing piston holes worth it, and does the SE-R MANUAL TRANSMISSION fit ???? in other ways can i really enlarge my pistons and place the manual transmission. MY SECOND question is tha since i have a header on already, is turbo or supercharger better ????
Old 05-02-2004, 10:52 PM
nacho_nissan nacho_nissan is offline
Send a message via AIM to nacho_nissan Send a message via MSN to nacho_nissan Send a message via Yahoo to nacho_nissan
Re: Help with my sentra pleaseeeeeeee !!!
...how the hell are you gonna fit skyline pistons in there? and the SE-R comes with a SR20DE, not the SR20DET(turbo). no the SE-R tranny wont fit! but you can get a GA16DE manual tranny. and just forget about your piston stuff, keep the same ones and get a HOTSHOT turbo kit. if your smart, you can get up to 250hp(the most ive seen on a GA16DE with turbo) on stock internals.
Old 05-03-2004, 06:52 PM
I want to custom fit them into my car, by drillling the holes of the pistons into larger ones where te piston will be aluminum made and lightweight for higher compustion i seen many people do it, and are u sure a SE-R maual transmission can't fit in my car????
P.S whats Tranny ???
Old 05-03-2004, 07:01 PM
tranny is transmission. no, the SE-R transmision will not fit a GA16. why would you want skyline pistons? get a turbo! you cant even make enough power to break the stock pistons man!
Old 05-03-2004, 10:10 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
You CAN fit the SE-R transmission in your car if you ALSO get the SE-R engine(SR20DE). Screw the piston idea. It would easily cost over $5000 to get the job done and is completely unessecary. Just get yourself the SE-R transmission, an SE-R ecu, an SE-R maf, and an SE-R drive axle. Then you can just get a FWD SR20DET and boost the shit out of it.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 05-04-2004, 03:20 AM
but is it true if i do the piston job it will make much more horse then add turbo ??? and what is the MAF and why do i need the drive axle ?
Old 05-04-2004, 01:58 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Re: Help with my sentra pleaseeeeeeee !!!
No that's not true, even if you could get that rb26 piston idea to work it would be a complete waste of money
MAF - mass air flow sensor, it measures the air flow and tells it to the ecu so the ecu knows how much gas to add, you have one now, it just wouldn't be compatible with the se-r ecu
drive axle connects to the transmission, your drive axle won't connect to an se-r transmission, so you need the axles from an se-r
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 05-04-2004, 09:11 PM
what is the difference betwene the sentra transmission and the se-r transmission? can i just get the sentra transmission and place a shortshifter, performance fly wheel and a heavy duty clutch?? what do u recommend
Old 05-05-2004, 12:59 AM
sr20de4evr's Avatar
The se-r has a different transmission. Different gearing, different bolt pattern etc. If you get an sr20det then you need an se-r transmission since it's the only one that can bolt to it. If you keep your engine then you need the transmission out of the manual version of your car.
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-05-2004, 01:18 AM
if i place the manual version tranny from my car, and i replace the fly wheel , clutch , and shifter to higherperformance would it be strong enough to race with ??? and i want to upgrade my ECU, do i buy a performanced one or the air/fuel boost thingy
Old 05-05-2004, 02:17 AM
fugiot's Avatar
Just the clutch will do fine, but definitely look into the flywheels also. For the ECU, get one from www.jimwolftechnology.com. Basically, all you need to do is get a new clutch, the ECU, and the hotshot turbo kit. Your car will haul ass.
Don't make me ANGRY
Old 05-05-2004, 04:35 AM
what is the purpose of the ecu and is it really necessary ??
Old 05-05-2004, 11:09 AM
sr20de4evr's Avatar
It runs your engine, and without it you would have a big lump of metal in your engine bay that couldn't do anything. Yeah I'd say it's pretty necessary.
'01 Black Sentra SE
'05 Silver WRX STi
Old 05-05-2004, 01:33 PM
thanx alot uve been a big help !!!!
Old 05-11-2004, 09:55 PM
nmone84 nmone84 is offline
Then again...why doesnt he just buy a new car?
/sarcasm
(so hard to pick on on the internet...always getting me in trouble )
