few q's on turbo KA24E
I have been researching turboing the KA24E, i am ready to start this project. At the moment i am only going to run 6psi on the stock engine. I am having a front mount intercooler put in, and a blow off valve put on.
I need a little info on feul upgrades. I will upgrade to a bigger feul pump 255 walbaro pump, BUT i need to know if i need to get my ecu tuned to use 370cc injectors. TURBO MANIFOLD : I was originaly going to order one from realnissan.com but they shut down a few days ago, anyone know were i can get one?
shinrekka 1 : i think the carburater needed to be rebuilt and were gonna drop the gas tank NoLlieSkillz : its called NoLlieSkillz : neutral drop at redline |
Re: few q's on turbo KA24E
iyou will need a sacf to get the full use out of the new 370cc injectors or else it will be a waste of $ the ecu will still see that you have stock njectors if you dont have afc..
1
![]() Shift_BOOST 97 s14 |
yeah same here about the manifold i know about the jgs one but i would feel better for one already made for me if anyone knows please help us out.
i'm looking for a sohc one too. thanks |
You could try Jim Wolf ECU... e-mail Unstable Hybrids and ask them about the manifold.
i e-mailed unstable hybrids and they don't make them any more looks like i'm out of luck and going to have go for jgs
turbo2nr, What do you think of a T3 running a .48ar turbine and a 60 trim compressor on a KA24DE at 6 lbs of boost? That would be safe on pretty much everything stock right?
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
Re: Re: few q's on turbo KA24E
yes it would that size is good for 6psi but if u plan to go with more boost later you will need a bigger a/r i honestly would go with atleast .55ar but if you dont plan on running more then 6psi the the .48 is good, but if you want you car to be realiable i really suggest looking into proper fuel managment for the turbo and make sure you have proper detaniation and make sure you aren't running lean after the turbo goes in.. get a egt gauge or at least a air fuel.. as for turbos t3 is good but i like the t3/t04 or even a t04b with a .54ar that would be nice also.. the 60trim compressor should be good enough for you application..
good luck 1
I was looking into a t3/t4. And yea i would definately get a air/fuel guage and probably a s-afc and a denzo fuel pump. Thanx man.
fyi s-afc wont work as well without upgraded injectors.. but good luck
1
for the manifold, contact www.back-yard-productions.com they make custom manifolds for the ka24de, so i'm sure they have made one or can make one for the ka24e.
shame to hear about realnissan
![]() as for a turbo... i personly will try to get a t25 or 28. virtualy instant spool... and since you plan on only running low boost, it should be fine.. as for manifolds, there is a group buy planned for a mani on 240sx.org. check it out. please dont flame me on the turbo choice, its been done with good results.
Need webdesign? I can help ==> 2design.da.ru |
eww t-25 ewww
its to small man i dont like t-25 they give problem on dsm and they have only 2.0l displacement the ka24de is 2.4l wid the dsm they fall out the powerband at 5500rpms so it not the ideal choice of turbo if it stops making boost at around 5k.. 1
Thanks for the tip but it still works right? Problems?
hey when that mani group buy goes down let me know i'm in
check 240sx.org for more info on the group by.
btw, you dont need to upgrade injectors for 6psi. just make sure they are in good shape.
