Old 05-01-2004, 10:09 PM
97chevycavgirl 97chevycavgirl is offline
Send a message via MSN to 97chevycavgirl
Thumbs up Have a blown head gasket? Read this.
I have a 1997 chevy cav Rs.....and runs very well. I love my car. However, my friend has a 1995 Cav Z24 and reciently blew a headgaket. It was slightly heating up for a few days, although not to red line or anything. Also it would occasionally miss. Within a week, the head gasket blew. He was told that it was going to cost $700 for the whole replacement and that it may not even hold after all that. Well, we heard through the auto-part stores that there is a Product that is called "Blue Devil Engine & Cooling Sealant". It ranges in price depending on the availability and whatnot. I've seen it in Parts Plus stores for anywhere from 48-65 dollars. However, IT WORKS. WE RAN IT THROUGH AND FOLLOWED THE DIRECTIONS, AND NO MORE LEAK, MISS, OR OVERHEATING. IT'S WARRANTIED AND A PERMANENT SEAL. IF THIS HAPPENS TO YOU....TRY THIS FIRST BEFORE PAYING OUT OF POCKET FOR A JOB THAT MAY NOT EVEN HOLD AFTER ALL. WHAT DO YOU HAVE TO LOSE? hope this helps
Old 05-02-2004, 07:54 AM
Three_Fingers Three_Fingers is offline
Re: Have a blown head gasket? Read this.
Hmm.. Wait'll ya inadvertantly seal up a water jacket passage. All that stuff does is get stuck in small holes. Depending on how much you put in-you can plug up some holes that you NEED.
You have no idea where it's going once it's in your cooling system-and furthermore-you have no say in the matter.
I just replaced the entire head on my 2.0 (cracked between the valves on 3 cylinders), and I could see all the "Bars Leaks" somebody had put in there.
It's a wonder any coolant made it through the head.
Hope ya one ofd the ones who got lucky.
Old 03-04-2006, 12:31 PM
lord_baul lord_baul is offline
Well, On the other hand. If you knew anything about this product, or products of this type. You would know that it will not plug ports, ruin heater cores, and anything of that nature. That is not how it works. There is absolutely no solid particls in the liquid of Blue Devil. Therefore it can not clog anything.
The way it works is it reacts to a temperature and pressure differance at the point of the leak, and acts as a catalyst.
Just like your blood. When it hits the air, it almost imeadatly thickens. After a few min it is normally solid.
Granted there are blood clots, but that is because of stuff that is not supose to be in your blood.
With Blue Devil, there is nothing in the liquid. And this is why they say to FLUSH the system first, and Rod out the Radiator.
I have a 97 Cav RS with a 2.2. It has a small leaky gasket, enough to overheat. Its leaking both into the intake, and out of the head. I used this stuff and it worked great.
Now i do keep some precaution. Within the next 6-12 months, I will eiter get another vehical, or repair the gasket on this one.
Old 03-06-2006, 11:14 PM
89Sunbird 89Sunbird is offline
If only Id known....I blew my head gasket a month and a half ago...just got the motor all back together $150 later...
Old 03-07-2006, 12:45 AM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
150 isnt a bad price tho is it? for a new head gasket and installation?
ThE neW wHiP:
Old 03-07-2006, 07:39 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
he probably did it himself,
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 03-07-2006, 11:13 AM
Yeah I did all the work....$65 to clean and mill the head, $85-ish for a gasket set, sealer, fluids, etc...
Old 03-07-2006, 01:05 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Give yourself a BIG pat on the back, or get a case o'beer. Not only did you save 100's of dolla's, you gained experience and, I'm sure, some confidence.
The best part is, if you screwed up, you have no one else to be mad at except yourself, and nobody ripped you off...
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 03-07-2006, 01:13 PM
Originally Posted by 4dr92cavi4cyl
The best part is, if you screwed up, you have no one else to be mad at except yourself...
Nah, I think that is the worst part, lol!!! But thanks
Old 03-07-2006, 01:41 PM
heh...be proud because i wouldnt even know where 2 start man...i woulda ended up payin someone like 100-150 to do the job.
ThE neW wHiP:
Old 03-07-2006, 01:54 PM
I was going to just drop in a v6, but I ran out of time, so I just decided to repair the 4 banger and maybe do the v6 later...
Old 03-08-2006, 11:57 AM
Well, I just completed a flush on my cav 2 days ago. Took me longer than expected, but seems worth it right now. I took a 1000 mile drive right after. It has not overheated yet. and i only had to put in maybe a cup of coolant. Ait pockets you know. so far, this blueDevil stuff works.
anyways... $150-200 for a head gasket replacement!! Where? Everywhere i go, they want close to a Grand. It is going to need one soon.
I bought my cav for $1000 a year ago, no real problems. Just needed Breaks, and a CV axel.
Old 03-08-2006, 01:52 PM
Ryan066 Ryan066 is offline
independent mechanics are the cheapest u will get the headgaskit done.
100-150 is do it yourself
200-500 is an indepent mechanic
1000+ is anybody else
thats the way i see it lol
