Old 05-01-2004, 10:02 PM
ppithug ppithug is offline
Unhappy 96 s-10 blazer starting problems
I have a 96 blazer, when trying to start it you have to turn it over for about 10 seconds before it will start. after it starts it runs ok just getting it started is a problem. any one else have this problem?
Old 05-02-2004, 01:39 AM
Mark Hart's Avatar
Mark Hart Mark Hart is offline
Hmmmm, could possibly be the fuel pump. The 4.3 V-6 in your car requires a fairly high fuel pressure to start and run. As the fuel pump ages, it takes longer for it to build up enough pressure to start. One easy test to try that helped me out: Next time you go to start it up, turn the key to the run position but don't start the car. If you listen close you'll hear the electric fuel pump run (it's located in the fuel tank). It should run for about 3 seconds to prime itself then shut off, turn the key to off and Wait 10 or 15 seconds then do the same thing. Do this procedure about 3 or 4 times then try starting the car. If it starts right up, I would guess your pump is on it's last legs. The above procedure is simply a way of priming the fuel pump to build up pressure.
Reply back and let me know what you come up with, Mark
Old 05-03-2004, 12:16 AM
stepontheduck stepontheduck is offline
When my fuel pump started going out in my 96 s10 blazer it started fine but would die after a few miles untill it got worse and worse until it would not start any more, so it could be something else. The fuel pump cost 800 bucks to fix because they had to replace everything.
Old 05-04-2004, 08:05 PM
Re: 96 s-10 blazer starting problems
Thanks for the info mark, but unfortunatly that is not the problem, it still took a while to start.I will post when I find out what it is.
Old 06-23-2004, 08:10 AM
Lar232 Lar232 is offline
I am having the SAME problem with my '95 S-10 Blazer. After checking my fuel pump, relays and wiring, I'm thinking oil pressure switch or ignition module. There are other posts like this in the Chevy S-10 section of this site. Let us know what you find.
Old 06-23-2004, 09:37 AM
Jeremy-WI Jeremy-WI is offline
Lar232
What motor do you have? Is it CPI or TBI injection? First thing to do is a new fuel filter. Then fuel pressure tests, TBI is usually 9-13 psi and CPI should be in the 50 psi range(not real sure on the pre-96 CPI but 96 and newer should be 60-66 psi 4.3L.
Old 06-23-2004, 10:41 AM
rharmon rharmon is offline
Who knows what it could be. I had the same problem reoccuring for months and I've gotten ALL of the above replaced and then some. Currently it's running but who knows if it will be in a week...
