Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 05-01-2004, 09:21 PM
geff31 geff31 is offline
crappy start olds 88
in the morning when it has just rained or theres moisture in the air the car sounds like its backfiring under the hood ...it has bottled for a while now almost like it has a bad coil had one replaced about a year and a half ago just started doing the rough start thing it also has no acceleration ...............any ideas?
Old 05-01-2004, 09:22 PM
Re: crappy start olds 88
it is a 94 olds 88 royale
Old 05-06-2004, 11:28 AM
Creative Creative is offline
Try removeing the whole Igition control module (( coils and bottom )) and sand the back of it clean and the mount on the motor ... the Aluminum to Aluminum corrodes and you add a little power it forms Aluminum Oxide which is a great insulator, hence you get a bad ground on the unit and this causes all sorts of problems ....... (( and you can also give it a thin coat of antiseize and it'll last alot longer, plus it makes removeing it later in life a breezze... )) And this is a common problem which seems to correct it self when the engine warms up (( and the metal expands )), And this has fixed several cars I've seen and cost you nothing other then a few mins of your time ...
And are you getting a Service engine light or not (( this will not cause the light to come on either )) If so let us know and I'll tell you how to get the codes from it and how to go from there .....
hope this helps you out ...
Creative
[email protected]
Old 05-08-2004, 10:18 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Don't forget about the spark plug wires itself. Older spark plug wires suffers misfire if there is moisture in the engine. Cheap spark plug wires does not have a good insulation.
BTW, make sure your spark plug wires are separated from each other with a spark plug wire sepator and use some tie wrap to move them away from the engine block and not touching.
One way to find out if you misfire or cross-firing, try starting the vehicle at night no lights. You might want to use a tarp to cover the open hood and around the front of the engine and see if you find some arcing or cross-firing.
The ignition coil themselves might have a crack around it and allows to leak out the high energy voltage from the ignition coil.
